high idle on an 03
Old Jan 3, 2008 | 06:12 PM
  #91
AH64ID's Avatar
Originally Posted by Hounddog
Just figure out a NEAT way to use a manual locking throttle cable work off the floor feed for a MANUAL FAST/HIGH controlled by our OWN fingers idle!: I bought some of the stuff to do such just with being ill and such I never got back to it.
They sell kits you can mount to your shifter.. .had one for my toyota 4x
By the way I did talk to a GURU that taught at a voc.school.Auto science.He said why not just TRICK the cruise so it can come on at a standstill etc.He said "I would need to look at wiring diagrahams" but don't think it would be real difficult.This conversaion took place in 04.He mentioned more on the subject but that was the jest of it.
I thought about this a few years back and IMO it wont work, you wont be able to speed up the fake signal to the ECU, so the CC would eventually end up at WOT, not a selectable speed.... right???
Old Jan 3, 2008 | 06:15 PM
  #92
vzdude's Avatar
DTR's 'Go to Guy'
That thought crossed my mind, but I have tried to use cruise when a vehicle is on a hoist ( to duplicaate a noise or vibration at a certain speed ) and it is VERY unstable. Can't seem to find a happy medium because of the lack of a load.
Old Jan 3, 2008 | 06:16 PM
  #93
Hounddog's Avatar
Hey were all in this for FUN! All these trucks have AUTO fast idle(I get TIRED of some newbie jumping in and saying "But MINE does it all by itself" What we WANT in our OLDER 3rd Gens is a MANUAL eaither by cruise function or?? FAST IDLE.Yea make mine THINK its a WRECKER with a roll back and RAMP UP.But don't cost us $400!
Old Jan 3, 2008 | 06:22 PM
  #94
Hounddog's Avatar
I have been told that the 3cyl.idle is LOUD and OBVIOUS.As I have NEVER heard one in my 5 years handling 2nd gens(yes it does get cold here, 17 last night) I can't say.But comments on the 2nd gen forum are like 'IT scared the HECK out of my neighbor at 5 a.m." after I got mine programed is not a comment I've ever heard from the FEW thats says their 3rd gens have 3cyl.idle.
Old Jan 3, 2008 | 06:24 PM
  #95
vzdude's Avatar
DTR's 'Go to Guy'
I would compare it to a small block with a fairly aggressive cam. Again, by the exhaust sound only. Engine....steering wheel....all still felt smooth.
Old Jan 3, 2008 | 07:12 PM
  #96
Spooler's Avatar
If you have an old Choke type pull you could put that in the cab and connect the cable to the top of the go pedal. The go pedal just pivots and pulls on a cable attached to the top. That should be real easy. All in the cab. Will need a ring loop at the top so when you press on the go pedal it can still pull more on the throttle cable. Just like a tractor does.
Old Jan 3, 2008 | 07:14 PM
  #97
vzdude's Avatar
DTR's 'Go to Guy'
That could be done, but I wanna do it cool and electronically! You know, like all the cool kids have with their new shiny, fancy trucks!
Old Jan 3, 2008 | 08:25 PM
  #98
Spooler's Avatar
Then the PTO route is the one to take.
Old Jan 3, 2008 | 09:41 PM
  #99
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by vzdude
This is my next call - to Marco or Bob. One question.......What kind of cruise buttons do you have? The teardrop shaped ones or the squared ones?
I have the square buttons
Old Jan 3, 2008 | 09:52 PM
  #100
vzdude's Avatar
DTR's 'Go to Guy'
BINGO!!! That seems to be ONE of the common factors that I have found so far out of all the ones near me that I have talked to. Why? Who knows, but every one's that does work, has the squared buttons. Now.....all I need is a new steering wheel and buttons right??!? LOL If it were only that easy! Talked to Bob Wagner tonight as well, he told me to talke to you soulezoo! We talked about yours specifically. I believe your's may have had the ecm replaced? We discussed the ECM and the breaking point of the ecm's, not necesarrily the production date of the truck as well. He was going to run it past Marco about my PTO idea. We'll see!
Old Jan 3, 2008 | 11:06 PM
  #101
soulezoo's Avatar
DTR 1st Sergeant
Well, my ecm is still the same one that the truck was delivered with. The only thing that has ever happened to it is smarty one way or another. I did some beta testing for them... the only thing I could offer is I had to do a forced reboot one time after the smarty jr testing. Otherwise it has worked as it is supposed to.
Old Jan 4, 2008 | 01:02 AM
  #102
no_6_oh_no's Avatar
It has to do with and when the ECM change came about.From a D.C. setup to a Cummins set up. D.C. ECM "NO Fast IDLE"by cruise system and NO way to download the software program much less turn it on.Somewhere in 04 or 04.5 Cummins software was used had to have fast idle program downloaded and then needed it enabled.Then 04.5? UP has the software already and just needed it ENABLED. This is the way I read the TSB's way back when the cruise control high idle was brought up and discussed early on(few years ago) Am I missing something?
I think you have that exactly backwards. Up to 04.5 is Cummins based software as evidenced by the Cummins software ability to hook into the ECU and read stored parameters. The 04.5 and up was the DC based feature set that Cummins no longer had any hooks into.
Leastwise that was the story we got from DC when the other links were removed.
Old Jan 4, 2008 | 01:20 AM
  #103
Hounddog's Avatar
Your probably correct.I knew it was one or the other!
Old Jan 5, 2008 | 09:32 PM
  #104
vzdude's Avatar
DTR's 'Go to Guy'
You know.......THIS just adds insult to injury. We have an 01 F-750 @ work, with a 5.9l and the VP pump. THE DANG CRUISE WILL RAISE THE IDLE ON IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!! It CAN be done ! I know it.......just have to figure it out! It has a pto too.
Old Jan 6, 2008 | 10:21 PM
  #105
soulezoo's Avatar
DTR 1st Sergeant
I really don't know what to say...
