High Idel?
Old Oct 13, 2008 | 07:55 AM
zack birge's Avatar
High Idel?
How do I enable High Idel on my truck guys? Does the smarty automatically do it or what? My Old banks system did it automatically but im not to sure on the smarty? Any help?
Old Oct 13, 2008 | 08:17 AM
MikeyB's Avatar
SMARTY enables high idle so you're good to go.
MikeyB
Old Oct 13, 2008 | 09:55 AM
zack birge's Avatar
Awesome so is there some point where it kicks in? like a certain temp.
Old Oct 13, 2008 | 11:10 AM
DieselBoy20's Avatar
Your truck will do the cold weather high idle no matter what if its cold, its a stock thing. What the smarty enables is the high idle manual adjustment on your cruise control. If its enabled hit the cruise button so cruise is on and hit set and it should rev up to around 1000rpm and you can ramp it up hitting the accell button up to 1500 rpms.
Old Oct 13, 2008 | 02:51 PM
zack birge's Avatar
Awesome thanks for the info!
Old Oct 14, 2008 | 11:32 AM
PRO-NRA's Avatar
If you have a G56 you will have to ground pin #22 on the B plug of the ECM.
Old Oct 14, 2008 | 04:25 PM
rodriguez7's Avatar
Has anyone figured out how to do this on an 03?
Old Oct 14, 2008 | 06:19 PM
pos dodge's Avatar
Mine wont
I know that my 06 wont do it. But my buddys 05 will. Sure when its cold outside it will do it naturally but i cant manually do it with the cruise.
Old Oct 14, 2008 | 07:42 PM
MikeyB's Avatar
The manual high idle feature isn't available on the '03.
MikeyB
Old Oct 14, 2008 | 09:33 PM
jamesbfishin's Avatar
You could stop in at the local dealer and have them go into the computer to enable that option. Mine wasn't turned on from the factory and my dealer did it for me.
CACalomino
Apr 16, 2009 01:30 AM
dieselkid6
27
Oct 2, 2007 05:50 AM
muddin_mavric
Aug 17, 2007 09:52 PM
charliex25
Oct 18, 2006 10:35 AM
Buckshotram
Mar 16, 2006 10:57 PM
