Help...........Truck stall while driving
Old May 8, 2006 | 10:54 PM
t20cl's Avatar
I left Houston headed to Des Moines and I was runnig from 70 to 85 mph all the way here but at mile 794 the truck all of a sudden just shut down for about a second and then came right back then again at 820 did the same thing.
I check the trouble codes and all it showed was
P0251 Injection Pump Fuel Valve Feedback ??????
Can anyone tell me what this means?
And will I be able to make it back to Houston.
I have a 2005 3/4 ton with an Xzillaraider race on 65 hp
and a magnaflow exhaust.
Old May 8, 2006 | 11:10 PM
Goose85's Avatar
Its a mechanical failure in your fuel pump, you might be able to make it back
Go to this site or read this
f your truck quits, take off the fuel filler cap. if you hear air rushing into the fuel tank like you just broke an air tight seal, it could be that you have a clogged/ melted fuel tank vent line. This could be starving your engine for fuel.
Or try to go to this site
http://flashoffroad.com/Diesel/troub...oubleshoot.htm
sorry, just trying to help you, would hate to have you not make it home.
flyingd
17
Jul 11, 2017 11:13 AM
Barrett_Fodder
Jul 24, 2006 07:11 AM
JD730
Aug 2, 2005 11:33 AM
BigBlue
Sep 9, 2003 03:05 PM
gs
May 6, 2003 11:08 AM
