Help Trans Question
Old Nov 12, 2007 | 07:56 PM
bziggy's Avatar
Help Trans Question
Hello I Need help and I hope some one has the answer. I have a Mag-hytec trans pan Part # 727dd. Holds 4 quarts extra. Any way it is tapped for a trans sending unit and they say it is 1/8" ntp. I have a VDO part801/9/1 , 1/8" npt sending unit but it will not fit into the trans pan. It is almost like the front part of the sending unit stops it from going in to the threads .I am not sure if any one eles has had a problems but if so can you tell me what you did on what sending unit you may have used please. Thank you
nvr-enuf
May 10, 2011 02:49 PM
jcmoyer2004
13
Jan 2, 2011 11:24 AM
Les Eid
Feb 13, 2008 09:22 AM
Billm2004
Oct 14, 2007 11:26 PM
