Help / Edge-Attitude Tire Size Adjustment?
In the instructions it says that the juice module transmission slip protection and mph will not function properly if you have had your speedometer re-calibrated for bigger tires (which I have had done).
So what is the point of selecting the option screen for adjusting tire sizes, since the instuctions state that it will not work if you have had your speedometer adjusted! ANY IDEAS???????????????????
Thanks, Rob
Thanks, Rob
Call Edge and don't post openings for opinions or false interpretations. They have been good to work with from my dealings. Give them a call and let us know the truth!!! Sorry, I have a stick shifter so I can't help you any.
Thanks, Rob
Thanks, Rob
Thanks for the smarta_ _ reply 4X4 dually. I know I can call them, I was just hoping that maybe someone out there may have had the same situation and was hoping for some insight. That is the whole point of this website!! Isn't it???
Ya. That is it. That dang lift kit deleted my program again!
I called them a few months ago and they said the trans slip function does not work if you have had you seedo recaibrated by the dealer. The said you either get the trans slip or a correct speedo, not both.
Cody Dodge
18
Dec 15, 2010 05:48 PM
sallyman1
Dec 18, 2007 08:20 AM
Big T
Apr 30, 2007 10:17 PM
Cummins600
Apr 8, 2006 06:24 PM
Igor
Oct 25, 2005 03:57 PM
