Doesnt edge juice attitude let you change tire size?
Unless things have changed considerably then the Juice/Attitude does not actually have the ability to change the ECM values related to tire size(ABS "Pinion Factor" up to 06). It allows you to enter a tire circumference that will display the correct mph on the Attitude speed display. It does not correct the OD on the cluster or at least it did not have that ability a year or so back.
Changing actual ECM values usually will require a downloader with that function or DRBII/StarScan tool.
FishBio31
Sep 17, 2010 05:02 PM
Red3quarter
Dec 12, 2009 11:12 PM
PowrStorkthsRam
Apr 26, 2007 03:50 PM
rjm022
Nov 16, 2006 01:13 PM
