Hell bent over Kore.....
Hey......
Can I add a Hell bent steel spacer to my front end if I all ready have a Kore Chase system....?
My rear end is still higher than my front and I want the truck up level...?
If your talking two inch then I would say no.... Unless you get Control Arms, End Links, Track Bar Drop, etc...... One Inch maybe ...... Either way ride will suffer........ Not because of leveling kit but because front shocks will loose travel..... In my opinion..........
I wish that I could find a 1" kit for my truck. I think 2" would make my front sit higher than the rear, but all the 1" inch kits that I have seen are for 2WD trucks. Also I could keep my stock shocks with a 1" kit.
I used the 2" hell bent kit and used my stock shocks and the ride did not change at all. and i got it off ebay for 90 shipped.
What about adressing the back??? Did you leave the overload with the MiniPak???? If you did is it because you tow??? My truck sits perfectly level without the overload..... Maybe its because yours is a megacab therefore it is heavier??? I have an idea for the front though contact KORE and buy the new Thicker Isolator they sell with the Upper End kits this will give you a little more lift up front
Kool ..... I will check with Kore....
bggrndodge
Nov 19, 2007 08:01 PM
zip
14
Feb 13, 2007 07:28 PM
MegaRam
Oct 29, 2006 09:44 AM
CDoskocil9
Sep 27, 2006 10:21 PM
BossHogg
Jul 29, 2006 05:20 PM
I'd lay off the brews and do a few sets of crunches in the morning.
