head LIGHTS ????
head LIGHTS ????
question on head lights bulbs see if you guys can help. it seems to me that my lights are really dimm They dont seem to put out much light at ALL that work really good when i hold in on the lever and get the low and high beams to work together. I need to know what bulbs i should get any nice bright lights out there I like that blue look some lights have.. what is that thanks
the "blue look" out there would be real hid lights. kits run from 500.00 bucks up to 2000.00 grand!! get a set of sylvania silverstars for around 40.00 bucks. a definate improvement over the stock bulbs.
I thought that the HID's would not work in our truck due to the dept of the reflector or something like that. If HID's do fit and work I will be out getting another set. (Had a brand new set in the box before I traded it in).
What bulb number do we use?
Kevin
Kevin
The Siverstar PN is 9007 ST/2 for the two pack. If you needed only one, the number would be 9007 ST.
I just removed my Silverstars last night from my 04.5 as I will trading it in next week. Removing all my goodies.
And as for the life of the Silverstars, I installed them in early spring of '04 when I bought the truck. When I installed them I made sure I wiped them down with alcohol and then made sure not to touch them again. This might be why some report the short life of the Silverstars, accidentally touching the bulb. So far, I have not had a bit of problems from them.
1. Realistic prices on HID kits are $225+
2. Silverstars suck, their for older folks that are too lazy or afraid to order a good quality bulbs like PIAA.
3. My GF put silverstars in her Taurus and I see any improvment at all, total waste of money.
4. PIAA's were beter then stock but not much.
5. I just installed GP Thunder 9500 in my 03 and it is soooo much better. I dont seem to blind oncoming drivers since ive never been flashed and you cant beat the look. It looks so nice, like a Honda S2000 or BMW. The only down side is you will want to change all your bulbs to match your new HID's
Go here if you want better lighting
http://www.hid-lights.com/
Originally Posted by BigDan
I dont know why everyone reccomends Silverstars, they SUCK and are a total waste of money.
Maybe your eyes are the problem? For me, the color that the Silverstars added seemed too help with what I saw when my headlights were on at night. I was not after a lamp that made the color of the light blue but a lamp that helped increase what "I" saw at night. I was offering helpful insights on how the Silverstars helped me. I was not posting in a negative fashion.
Quick question here. I do know the headlight housings have been restyled for the '06's but are the lamps/bulbs the same? I would think that the lamps/bulbs would still be the same.
Might just to have to start a new thread on this.
Carl
Ok, I hate asking dumb questions but here it goes. How do I take the headlights out to replace the bulbs? I took off the 2 screws holding the headlights but I can't seem to get the corner of the light close to the fender to come out.
