Have 3 Guage A pilliar mount...where else to put two other guages?
I've already got an A pillar mount for dipricol egt, boost and trans....want to get rid of my quad fp/rp guage and mount two additional diprocol fp and rp guages....dont like window / mirror mount as im in arizona and it wont stick with the heat...dont want them in the dash...
I want to put them either by the a pillar (on the dash) or on the center counsol where the floor section meets the vertical section....the 06's have an area i think might work....
Any thoughts? Just wish the quad would read the flippen fp consistantly....so i wouldnt have to drop $350+ on something i'm already supposed to have.....and do the diprocol electrip fp guages work worth a dammm?
Thanks in advance
Thanks in advance
Gauge mounts
Thanks in advance
Thanks in advance
I am running the DiPricol rail pressure gauges for over 1 year and have not issues with it. I am also running the pyrometer and boost guages. The pyrometer went haywired for a bit then corrected itself; I suspect an intermittent wiring problem to the thermocouple mounted in the exhaust manifold. Although DiPricol gauges are manufactured in India I have found them to be first rate. Good luck with your setup.
L8r,.......dogger
What about the 3 piller mount and 2 on the dash pod? I haven't seen that before, I wounder if they make a 2 dash pod. I know they make a 3 dash, so you could do a 2 piller mount and 3 dash pod. That's what I'm looking into doing. Thoughts?
NeedMoPower
02-18-2005 06:00 AM
Dieseldude4x4
01-04-2003 03:07 PM
tobyw
11-13-2002 09:11 PM
