Top two guages
Old Nov 23, 2008 | 08:14 PM
Rickcher's Avatar
Top two gauges
If you could only install two gauges on a 1st gen (intercooled), which two would you choose? Not counting a tach. Stock motor.
Old Nov 23, 2008 | 08:19 PM
user name's Avatar
would a low pressure warning light for fuel pressure count as a gauge? I'm going to say it doesn't and go with that trans temp and pyro.
Old Nov 23, 2008 | 08:22 PM
DNRCustoms's Avatar
#1- Pyro
#2- Boost
#3-Trans
#4 Fuel pressure..might want to bump this up depending on what mods you are doing..
This is just the way I would do it, or doing it..lol
Old Nov 23, 2008 | 08:23 PM
keith1992's Avatar
Transmission Temp and Water Temp
Old Nov 23, 2008 | 08:28 PM
Montana2x2's Avatar
1-Pyro if you plan to add more fuel
2- Trans temp if you have an auto
3-fuel pressure
Boost is interesting but in my opinion not necessary unless you have a lot of fuel and turbo and are getting to the point you need to know your boost to save your head gasket.
Old Nov 23, 2008 | 09:16 PM
pyro and fuel press.
Old Nov 23, 2008 | 10:38 PM
bullfrog5.9's Avatar
3-fuel pressure
i agree with his list
Old Nov 24, 2008 | 07:20 AM
Play truck: Pyro and boost
Working truck/stick: Pyro and boost
Working truck/auto: Pyro and trans temp
Old Nov 24, 2008 | 08:48 AM
93Fury's Avatar
Fuel level and a clock, the only two gauges necessary in any vehicle. Even more important than a tach or speedometer. As long as you have fuel you can be sure to get there on time.
Old Nov 24, 2008 | 10:36 AM
Ace's Avatar
Ace
I'll say pyro and oil pressure. Those are the two that'll save you the most money from hidden condtions before it's too late. Don't trust the stock oil pressure gauge.
Old Nov 24, 2008 | 07:41 PM
Montana2x2's Avatar
I stand corrected.
Old Nov 24, 2008 | 08:01 PM
Richie O's Avatar
366 Spring Chicken
Not looking for brownie points,,, but wanna is right.
Old Nov 24, 2008 | 08:14 PM
TWorline's Avatar
......or to tell how much boost it took to blow your head gasket!
BossHogg
Jul 29, 2008 09:51 AM
jgiachino
Jul 28, 2008 03:12 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
