Has anyone ever removed the heater grid on warm climate trucks?
Old Jan 17, 2007 | 03:23 PM
LooseBoltsRob's Avatar
I live in Florida and have no use for the intake grid heater...it's nothing more than a restriction for me in the warm climates of FL. Anyway, has this ever been done? Will it throw codes if disconnected? Anyone make a spacer to eliminate it without making intake mods?
thanks!
Old Jan 17, 2007 | 03:40 PM
PourinDiesel's Avatar
Yeah www.powerbypoole.com has the spacer...Its called "Power Blok"
I run one on my truck even in the cold winters out here.
It take about 5 seconds of cranking before my truck starts much of the time in the winter...then it smokes white from the colder intake air charge.
Old Jan 17, 2007 | 04:26 PM
cquestad's Avatar
How much or a restriction do you think it is? I would love to get rid of it in the warmer months. Do you think it puts much moe of a strain on the starting system if it is 50 and above?
It seems like a bottle neck in air flow.
Old Jan 17, 2007 | 04:28 PM
stang's Avatar
John at Floor it Diesel sells them also 785-842-8545
Old Jan 17, 2007 | 04:45 PM
sleds's Avatar
I also build these. They look nice, but, when I dyno tested them there was zero gain in hp.
Old Jan 17, 2007 | 04:47 PM
cquestad's Avatar
EGT drop? Dyno vs Sled/Real Life?
Old Jan 17, 2007 | 04:54 PM
That's surprising. It sure as heck looks like a restriction. What do you do with your old cables? Anything to disconnect to prevent codes and/or shorts?
What level of HP truck did you dyno where you noticed zero gain?
Old Jan 17, 2007 | 07:13 PM
Jus Cruisin's Avatar
You must live way south. My grid heater comes on pretty often in the morning (7:30 or so)... too often (hate the cold). Came on this morning, 59 degrees on the overhead.
Old Jan 17, 2007 | 07:37 PM
sleds's Avatar
The truck was a 2nd gen 24 valve with a 66 turbo at around 650hp. I've never tested these on the 3rd gens, so I shouldn't say they won't help, because I know the intake horn has more restriction than the older trucks. Also, they would probably make a bigger difference on trucks running twins with more air flow.
Old Jan 17, 2007 | 07:42 PM
Guys you probably wont see a dyno gain with just this mod.
But I chalk it up as a restriction and freeing the way for airflow is only GOOD!!
rbrettctd
Jul 22, 2007 01:37 PM
SolarYellow05
Jun 22, 2006 04:55 PM
Spitse
Jan 21, 2006 06:36 PM
deezel
14
Apr 3, 2005 04:39 PM
grizzly660fan
Jan 2, 2004 10:02 AM
