Goerend Bros.
Old Aug 27, 2007 | 09:29 PM
  #31
jgiachino's Avatar
Originally Posted by jrussell
The aggressive downshift to 2nd doesn't bother me at all. I actually prefer it that way because it helps keep the RPM's up during city driving. Makes the truck much more responsive. It's much better to have it that way than the alternative (2-3 "cut loose" problem).
In traffic, when i'm accelerating lightly...meaning to slowly increase speed and it downshifts to 2nd and the rpm's come up, it's not too enjoyable.....then it pops into 3rd and i'm shooting for the rear end in front of me.....
If i didnt drive in traffic no problem, but every morning is annoying.....
Hopefully, the stiffer spring will help, if not, maybe a new vb??
Old Aug 27, 2007 | 09:30 PM
  #32
92'1stGen's Avatar
I'd like a Goerend trans but he's on the other side of the country and I have no where near the time to drive out there. I don't plan on programming the truck, I just can't stand the stock slip of the TC when it's unlocked.
Old Aug 27, 2007 | 09:35 PM
  #33
jbrown93's Avatar
hey six pack call dtt in washington u need a pressutre fooler...
Old Aug 28, 2007 | 07:46 AM
  #34
jrussell's Avatar
Mine doesn't do that. It only downshifts when you let up on the pedal and/or the truck is slowing down.
Are you pressing the pedal further than needed to get the truck moving and then letting up a little just before the 2-3 shift? That will cause it to happen on mine.
Old Aug 28, 2007 | 08:23 AM
  #35
yfz431's Avatar
Same situation here, I'd buy Goerend's trans in a heartbeat but don't have the time to drive out there and don't know of any shops near PA that could do the work The stock tranny in this truck is the weakest link and I also think my fuel mileage is suffering because of it.
Old Aug 28, 2007 | 08:29 AM
  #36
jrussell's Avatar
Guys, just buy a whole trans from Goerend and have it swapped in. Any basic mechanic/trans shop can do the swap for you. If you don't have a local trans guru then might as well go with someone like Dave who stands behind his work and his warranty.
Heck, I drove all the way from Utah to have Dave do mine! Well not exactly...I was kind of in the area for other reasons.
Old Aug 28, 2007 | 09:43 AM
  #37
soulezoo's Avatar
DTR 1st Sergeant
I agree!! I was already to drive all the way there when I found a local guy who could/would do it all for me. I was in contact with Dave Goerend throughout the process so he knew exactly what I wanted. The install is very straight forward. I could not be more happy. If nothing else, Goerend can recommend an installer near you.
Old Aug 28, 2007 | 11:31 PM
  #38
bigwheels94's Avatar
My dealer installed mine in less than 5 hrs. Test drive, & all. He thought my truck was pretty fast...
Old Aug 29, 2007 | 12:30 AM
  #39
jgiachino's Avatar
Not necessairly, just light consistant throttle...
Old Aug 29, 2007 | 05:59 AM
  #40
coolslice's Avatar
You've got that right. My mileage was really falling off before my transmission upgrade. I have yet to run a full tank thru with my new setup to check the actual mileage but I can tell you that the gain is significant.
cameroneod
May 6, 2007 02:55 PM
ataboy9026
Aug 22, 2006 09:06 PM
qcstunter
19
Aug 4, 2006 05:47 PM
rebal
Mar 8, 2006 06:45 PM
juice
Mar 5, 2006 08:02 PM
