glacier fuel system has low fuel pressure?
my comp glacier system is only reading about 7psi and normally reads about 18-21. is it just the cold weather since it is about ten degrees outside or what do you guys think is my issue? I checked the pump and it seems to be running fine and I changed the fuel filter in the stock canister and doesnt really change much. I took the inline strainer off also and it doesnt seemed to be clogged. you can blow air thru it. any info would be appreciated. I havent had issues with this fuel system and im not trying to bash on glacier diesel in any way. I just want to fix the issues of low pressure is all I want to do.
the little inline strainer that is like a fleetguard? I plan to get a couple new ones when I can. when I took it apart the local napa that has them was closed. I had a spare and gave it to a buddy that was having problems
Does the truck "run" like it has weak fuel pressure? May try a different guage, but it could be the filter too. You can get the inline strainer about anywhere. I keep an extra in the truck, as well as an extra for the factory canister too.
Loose the isolator, run the FP line directly to the gage. They are notorious for failing or getting weak. 90% chance this is your problem with no loss of FP. However, cold weather can cause a few PSI difference, but Indiana is getting real cold right now. Make sure you have added an anti gelling additive like PS.
. I havent ran the truck really hard, but I got on it good today and it seems to run fine. my friend has issues with his isspro fuel pressure gauge and removed it
I wish they made a spin on style like this just to make changing it out easier and less of a mess.
JWB, Did you determine what was causing your low fuel pressure?
Strainer is Fleetguard#FF5079 I buy them from a local cummins shop. Be carefule with some of the same style from auto store as they may have paper filter media and clog up quicker that the fleetguards will as the fleetguards use a stianless screen. Glad I keep extras in my truck as I lost fuel pressure this morning when I went to leave my office. Made it about a 1/2 mile up the road and truck died. Changed this pre-filter out and had 19lbs of fuel pressure again and headed down the road. It has to be when it is cold and the filter is somewhat clogged up that they gel up? It was not even that cold this morning 20-25 degrees? I am running an electic pressure guage with sensor mounted in the line going to my CP3.
well my problem was simple. when I got home this morning I took my isolater apart and it was about half full of coolant. I filled it up and put it back together and now my gauge shows 20 psi again. I did talk to richard and he said he figured it was something to do with the isolater. thanks to the guy who said check the coolant in it because you were right
theonlyz
Feb 24, 2007 12:29 AM
OT-OF-Here
Sep 27, 2006 10:21 AM
Igor
Jun 2, 2006 07:49 PM
