Give me your advice on a turbo for me...
Old May 20, 2008 | 04:52 PM
cummins dsl's Avatar
I know it's long but please give me your opinions.
I have a question for you about turbos. You may or may not be able to give me any info, but I am looking for turbo's in the 62/??/13ss or around this size maybe even with a 12cm exhaust housing, i'm not sure what size compressor wheel I should go with so give me some ideas there after you finish reading. I am about to start hot shoting in the oilfield since our family has started a oilfield service company and I am looking for a little more power. My plans are to beef up the tranny to whatever point required, possibly adding a fuel system with better filtering or just a GDP 2 micron filter first. From there I'm looking at adding a smarty to run on lower levels when towing since I will be capable of grossing around 35K (won't be all the time) with the gooseneck, but when I'm not towing I want to be able to run the smarty a little higher and use my X2 to add a little pressure to the mix (I know with my setup I will not be able to crank the smarty up all the way and i'm fine with that but want to have about 450hp to play with when not towing). Now back to my main question, I know these trucks already run hot completely stock when towing a loaded down 40' gooseneck and I would like to lower the EGT's without causing to much lag so I am looking at a smaller turbo that can handle a the smarty around 60hp while working and keep the EGT's at stock levels or lower than stock. But at the same time support higher HP than the stock turbo for when the trailer is not hooked up. I'm looking to keep it simple to try and maintain reliability with this truck.
I know that doing any of this can/will hender the reliability and that changing the turbo I will most likely experience some lag at some point and I am ok with that. I will compromise to make it work for me both towing and playing. All my playing is just on road, I won't be doing track stuff, just one of those you know you have type of things.
Sorry for the long post but please give me your advice here.
TIA
Old May 20, 2008 | 05:01 PM
jrussell's Avatar
Since you tow heavy and don't plan to exceed 500hp, it sounds like smaller would be the way to go...like a 62/65/13SS. I think a 64 compressor and/or a 71 turbine wheel would be too laggy for the power level you'll be towing at.
You might actually be better off with the stock turbo. It cools 450hp just fine and will give you lower cruising/towing EGT's.
Old May 20, 2008 | 05:13 PM
Spooler's Avatar
HTT 62/65/13ss and don't look back. A 71 wheel is not what you need at all.
Old May 20, 2008 | 06:05 PM
Tacsavage's Avatar
HT 62/65/13ss
Old May 20, 2008 | 06:43 PM
metalbasher's Avatar
How about a BD super B. Nice low end, rated for 425 HP.
Old May 20, 2008 | 06:48 PM
bigwheels94's Avatar
62/65/13ss all the way. Anything bigger, & you'll smoke all the time, & be too laggy.
Old May 20, 2008 | 08:14 PM
nelrod's Avatar
I have an HTT 62/65/13 SS and LOVE it. Would get same one again. NO LAG at all. Will bark dual rear wheels in 4th gear. If wet on Interstate, going 65mph, stomp it and it breaks the tires loose. I got it in case I ever tow more than I do now, but it is a hoot to play around with.
Old May 20, 2008 | 08:22 PM
homewrecker's Avatar
Another vote for the 62/65/13ss!
Old May 20, 2008 | 08:26 PM
Diggie's Avatar
I have the 62/65/13ss and absolutely love it, and it tows great!
Old May 20, 2008 | 08:57 PM
Thanks for all your opinions, looks like I know what I'm going to be getting.
Old May 20, 2008 | 09:22 PM
THURENfab.'s Avatar
Um..... 62/65/13ss
LOVE IT!!!
Get the RPM's up a tad and the EGTS are great..
Smarty on Revo TNT #9 I can BARELY get to 1450 degrees..
Boost on tap from 1100rpm..
Old May 20, 2008 | 10:51 PM
kuhkuhkyle's Avatar
You can tow with that monster???
Old May 20, 2008 | 11:59 PM
tburks's Avatar
PS 62/65/14 I tow heavy and it is great.....
Old May 21, 2008 | 09:44 PM
I haul my camper over mountain passes all the time, & have yet to hit anytihig over 1330*, & thats with Smarty 4.4 on SW9! 50mph. to 75 mph in about 3 seconds. & thats weighing about 12K on a 6% grade. 42# boost. Trust me you'll love it.
ARIZONACLASSIC
May 11, 2011 12:56 PM
pogo1
Nov 18, 2010 10:17 PM
dslpwr81
Oct 3, 2008 02:06 PM
ftltmp
Sep 13, 2007 09:48 PM
Rob_OBX
Sep 11, 2006 12:42 PM
