Gauge pod location choices
Old Oct 4, 2008 | 09:10 AM
CanuckGT's Avatar
Looking to get a set of gauges but am leaning to the in dash pod as to the pillar location,just wondering if it is more difficult to run the wiring ,etc to this location instead of the pillar? Also, the dash mount (to fit in the empty slot below the stereo) are the designed so the gauges are angled towards the driver? I have never seen these installed yet?
TIA
Old Oct 4, 2008 | 09:14 AM
CoolumConst's Avatar
I am going to do the guages under the heater control. I have not seen them installed yet but I think they would work pretty good there. They are angled.
Old Oct 4, 2008 | 10:07 AM
jrussell's Avatar
TIA
What year is your truck? I think the in-dash pod only fits the 05's.
Old Oct 4, 2008 | 10:10 AM
CanuckGT's Avatar
Sorry, 2003 Dodge 2500 quad cab 4x4, Cummins,auto.
Old Oct 4, 2008 | 11:07 AM
mpracehemi's Avatar
Why don't ya fill in your signature, that let's everyone know what you have. To fill that in go to user cp to the upper left of your screen.
I have the steering column mount for 2 gauges, have a 3rd mounted in the middle in a pod. Check out my pics. and you'll see it. I like it, I run mech. gauges hiding the braided lines between the dash and col. It's auto meter's pod for $30 through jegs or summit. If you need part #'s let me know.
Old Oct 4, 2008 | 11:26 AM
2007 5.9's Avatar
I have 1 gauge in a Srt-10 pillar, so I can keep my handle. 3 gauges in dash pod on the left side of the dash, and 1 gauge on the steering wheel.
Old Oct 4, 2008 | 01:04 PM
N.Johnson's Avatar
Old Oct 4, 2008 | 01:30 PM
JWillms81's Avatar
I have had both, A Pillar and under the AC controls. They are about the same as far as install, the in dash ones you have to run the wires a little bit further and hide them under the dash but not hard to do with some zip ties.
J
Old Oct 4, 2008 | 09:26 PM
CanuckGT's Avatar
Thanks guys,good info.Looks good NJ,just curious why does one need a manifold pressure gauge??
Old Oct 4, 2008 | 09:45 PM
RamWheelsBy4's Avatar
The 3 guage Console Pod does angle the guages toward the driver. It is probably the easiest to install gauges in. I also have a two gauge steering column pod that works well also.
Old Oct 4, 2008 | 11:05 PM
coxy11's Avatar
gauge pod
Where did you get the console gauge pod at. I think thats what I want to go with.
CanuckGT
Oct 4, 2008 02:19 PM
VALVEGUY1
Mar 19, 2008 07:54 PM
59FORD
Apr 7, 2006 12:28 AM
scarecrow
Mar 9, 2006 08:12 PM
lil jim
Apr 8, 2005 03:40 PM
