Fuel system on stock truck...worth it?
Old Feb 17, 2008 | 01:17 AM
RedRacer44's Avatar
Just as the topic says...
Just browsing around for new things to buy for the truck and was wondering if there are any major benefits for adding a fuel system to a relatively stock truck?
I already have the in-tank lift pump (killed the old style pump @ 40k)...
I'm a daily driver with a rather conservative right foot so its not like I need fuel to support SW#9 on a daily basis...know what I mean? Just wondering if there are any benefits for the daily driver who uses SW #3 or SW #5 mostly....
Thanks again like always guys
Old Feb 17, 2008 | 01:25 AM
trik396's Avatar
Probably not absolutely neccesary but I believe it's a good idea. I would pull fuel press down to zero on WOT with just XZT box before my pump install.
Old Feb 17, 2008 | 01:43 AM
DaveB.inVa's Avatar
I'd say its a great idea even for SW #3 or 5.
My first mod was gauges and the second was the Glacier kit with the big line and 2u filter. I did notice a slightly smoother idle when I installed it. Now I will say that may have been my mind playing tricks on me but I have absolutely no regrets about the install.
Now I've got the great Glacier kit running and have the stock system available as an installed spare should I need it.
The way I look at it is like building a house. If you want your house to stand you've got to have a good foundation. Same way with our trucks, if you want to support much more than stock power you've got to have a good fuel supply with sufficient volume, pressure and probably most importantly cleanliness.
Old Feb 17, 2008 | 11:09 AM
RedRacer44's Avatar
Thanks for the input! All good points...
If nothing else, I would think the reliability of a fuel system (mainly the fuel pump) would be worth it....I'd think?
Doesn't most of the aftermarket fuel systems have warranty?
Old Feb 17, 2008 | 11:01 PM
RedRacer44's Avatar
Anymore input?
Old Feb 18, 2008 | 12:46 AM
tristan21's Avatar
All of the aftermarket ones have a 5 year (fass) and the rest a lifetime. I think thats right.
The air seporater made alot of difference on mine.
Old Feb 18, 2008 | 12:58 AM
Mighty Goat's Avatar
Yeah, a Walbro is a very capable pump. At the pressure's and volume's we run, it'll theoretically last a life time. I didn't need one as I had the in-tank OEM conversion when I bought mine as well. But, I'm glad I did it b/c it's one less thing to worry about failing. But, I built mine to be fully adjustable and currently run it at 38psi with a bypass regulator. I'm not a big fan of the GDP check valve. But, I did buy parts from GDP and have faith in Rich's system. It was just a personal preference. But, all and all, I'm with the rest of these guys. Get a fuel system. It's money well spent.
Old Feb 18, 2008 | 09:08 AM
RedRacer44's Avatar
Alright...good deal. Guess I will put that onto the list of add-ons coming....
Now if I could just figure out where to get some $$$ to buy a tranny...
Old Feb 18, 2008 | 12:14 PM
durasnack's Avatar
Geez chance, i thought you said you were done?!
Old Feb 18, 2008 | 10:28 PM
RedRacer44's Avatar
LOL...well hello Phil! Done...heh, I thought I was done...
Still haven't ordered the 5" exhaust yet....gotta buy tires for the truck first thing....
Nittos got over 30k on them....heh, almost wore smooth out!
Old Feb 19, 2008 | 01:49 AM
Kman9090's Avatar
YES! These fuel filters on these trucks are not effeciant. You need to get a fuel system with a 2 micron filter.
GillRipper
Nov 5, 2012 01:33 PM
MulesDiesel
Sep 12, 2009 04:19 PM
mstep3
Sep 8, 2009 06:11 PM
man doore
Apr 7, 2008 08:17 PM
