Fuel Question ?
Old Mar 31, 2008 | 07:29 AM
mulisha's Avatar
Fuel Question ?
question fella's. i have an 07 5.9, with none of that DPF or emmissions junk.should i be running ULSD or LSD. and also should i be using 2 stroke, or ATS oil in the tank for some lubrication. thanks guys
Old Mar 31, 2008 | 08:22 AM
DiezelSmoke's Avatar
Either one, and no oil needed.
Old Mar 31, 2008 | 08:54 AM
AkitaSumo's Avatar
No worries, you will ony be able to find ULSD in the good ole' USA...
"United States
As of September 2006, on-highway diesel fuel sold at retail locations in the United States is ULSD[4].
Ultra-low sulfur diesel was proposed by EPA as a new standard for the sulfur content in on-road diesel fuel sold in the United States since October 15, 2006, except for rural Alaska. California required it since September 1, 2006, and rural Alaska will transition all diesel to ULSD in 2010. This new regulation applies to all diesel fuel, diesel fuel additives and distillate fuels blended with diesel for on-road use, such as kerosene, however, it does not yet apply to train locomotives, marine, or off road uses. By December 1, 2010, all highway diesel will be ULSD. Non-road diesel transitioned to 500 ppm sulfur in 2007, and to ULSD in 2010. Locomotive and marine diesel also transitioned to 500 ppm sulfur in 2007, and to ULSD in 2012. There are exemptions for small refiners of nonroad, locomotive and marine diesel that allow for 500 ppm diesel to remain in the system until 2014. After December 1, 2014 all highway, nonroad, locomotive and marine diesel produced and imported will be ULSD..."
Old Mar 31, 2008 | 01:00 PM
DBLR's Avatar
You can buy LSD in many places (like many Flying J truck stops) except the state of CA. The EPA allowed the sale and use of LSD for on road use until 2010 so long as 80% of all diesel made is ULSD. IIRC all refiners have to stop making LSD for on road use by the last day of May in 2010. Also you don't need to be using any 2 cycle oil as its not needed.
Old Mar 31, 2008 | 02:27 PM
mulisha's Avatar
thanks fella's
Rick 12v CTD
Sep 12, 2011 11:49 PM
retirednak
Mar 30, 2010 11:00 PM
txasylum
Mar 22, 2008 02:47 PM
stock600
Mar 3, 2008 05:42 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
