fuel pump noise?
Old Apr 9, 2010 | 08:56 PM
Tmain's Avatar
fuel pump noise?
Hi Guys, for the past couple month I have noticed a noise after start-up that I haven't herd before. It sounds like my fuel pump (raptor 100) is cycling like a two speed pump. The truck starts fine and the noise starts up after about 30 seconds, then it cycles a hi and low pitch sound every 30 seconds or so for a couple minutes then is becomes steady like a fuel pump. I hear a relay switching as it cycles but I can't locate it. I have temporarly disconnected the power to the fuel pump and the noise goes away. I have changed the fuel filters and checked the raptor fuel pump inlet screen, no change. The truck starts and runs fine, I just don't want something to fail and leave me stranded. Is this normal, maybe the alternator is re-charging the batt's after starting and the voltage is fluctuating causing the variation in noise.
Any ideas or suggestions would be appriciated.
Thanks.
Old Apr 9, 2010 | 09:22 PM
gunnie's Avatar
Could it be your grid heater kicking on and off pulling the amps down giving you different tones on the fuel pump?
Old Apr 9, 2010 | 09:36 PM
Tmain's Avatar
That's what I thought, so I pulled the fuse for the heaters and there was no change.
stealman
Dec 27, 2013 08:03 PM
Smkn600CTD
May 22, 2012 07:21 PM
3J1&3J2Bill
Jul 7, 2010 06:00 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
Commatoze
19
Aug 8, 2004 09:57 PM
