Fuel Filter vaccum guage???
Before i knew much about the Cummins fuel system, i went ahead and got the FP guage out of the bottom of the fuel filter housing. I work on diesel engines in the marine industry and we have vaccum guages on our RACOR fuel filters to tell when to change our filters. When they get about -10 we change our filters. Is there a place between the filter housing and the IP to place a guage there to tell when to change the filter? Or is there something else out there that can be a tattle tale to change the fuel filter. I know rule of thumb is about every other oil change or 10k miles (some people do it sooner) but with a guage telling you when to change it (like my RACOR's) it would be that much easier.
Filter Gauge
Good question. I work with Racors daily, those 2020's and R20S's, on tugs and also wondered about putting a vac. gauge on my truck. I have'nt started diggin around on the truck yet because I'll be installing the FASS soon. I think the Fass has a port that could be used, or at least T'd into the suction line, not sure on the factory system. May have to crawl around there later today.
you could install 2 gauges, 1 before the filter, 1 after and compare the differential. you'll have to use a new filter as a baseline. or, what's the pressure with a new filter? move the gauge fitting between the filter and cp3(mines on the cp3 inlet). when you notice less pressure at the cp3, change her out.
OldDodgeOwner
Feb 13, 2009 05:13 PM
bigragu
Jan 24, 2006 11:16 AM
