Question on fuel filter lid & fuel pressure guage
Old Feb 8, 2009 | 05:24 PM
OldDodgeOwner's Avatar
This may be kind of a dumb question, but I was wondering how you guys plumbed your fuel pressure line into the top of the filter lid. Now it's not hard at all to screw a fitting in to the top, but how do you have it setup to pull the lid when you change your filter?
I haven't got it completely hooked up yet, but I've got a braided line to run straight from the guage to the filter lid, with a needle valve and swivel connection at the filter so I can close the valve and disconnect the line when I change my filter.
Basically just wondering if anyone had a better setup or a better idea. I was thinking quick-connects, but couldn't find them in 1/8" and didn't want to add any more fittings to the system.
Old Feb 9, 2009 | 05:19 PM
Anything???
Old Feb 9, 2009 | 08:37 PM
hink's Avatar
Buy a tapped banjo bolt and put it in the bottom of the filter housing.
Remove the stock banjo bolt, screw in the tapped banjo bolt, re-install the factory line and attatch the plumbing for your FP gauge. No need to mess with the lid.
Here's a link for reference........http://www.vulcanperformance.com/ban...ss-p/tbblt.htm
Old Feb 10, 2009 | 01:31 PM
Silver R/T's Avatar
What about all the dirt that collects on the bottom of the canister, wouldn't that clog up line?
Old Feb 10, 2009 | 01:53 PM
Dr. Evil's Avatar
Heres a pic - thanks to Moose10 this is on an 01 (dont forget the needle valve):
Back to the original question - heres a few more pics from the site (I believe both these trucks are 99's):
Old Feb 10, 2009 | 02:21 PM
hink's Avatar
That dirt does not enter the outlet to the IP.
Now after reading Dr. Evil's post (which is a good one BTW), I realize I was off base on my post. I forgot that some years had the outlet on the top.
Old Feb 10, 2009 | 03:09 PM
PaulDaisy's Avatar
That's correct. My 98.5 has two NPT fittings on the lid, one inside the filter and one outside the filter. I thin kit is 2000+ that switched to a plastic lid, and one needs to use a tapped banjo on the bottom of those.
BTW, I tapped my own banjo bolt without any problems using a bottoming 1/8" NPT tap and drilling to 21/64".
Old Feb 10, 2009 | 05:30 PM
Thanks for the replys.
I've got a 2000, and I've got 2 options. I've got a filter lid from Geno's with the 1/8" port on top and I've also got a spare tapped banjo bolt. I was looking at using the filter lid port just because it's a whole lot easier to get to. I can barely reach the banjo on the bottom, much less getting wrenches on and not messing anything up. The only thing I don't like about the filter lid is if I had to undo the line every time I change a filter. I haven't changed the filter in a while and it's due. I can't remember how many turns it takes before it comes loose, that's why I was thinking of using the swivel connection.
The reason I want to use the filter housing is because the braided line I have is long enough to reach it, but won't reach the injection pump. I also have my low fuel light sender on the IP and want to leave it there as a kind of visual backup. Trying to do this as simple as possible with the least amount of connections to possibly leak down the road...
Old Feb 13, 2009 | 03:11 PM
PaulDaisy's Avatar
I did not have any issues replacing the bottom banjo bolt with a tapped one. Right, you can't see it and have to work by touch but it is not too bad. I liked that option on my friend's truck because he had no Geno's lid anyway.
If you use a good quality fitting for the line on Geno's lid, taking it off for filter changes will be a painless deal as it is so accessible. Crappy fittings such as Parkers have potential to kink on the flex line after a while. If you use Swagelok you can take it off and put back on as many times as you want and it will not leak.
Old Feb 13, 2009 | 05:13 PM
Well, I just got it done last night. Decided to go with the banjo on the bottom, pain in the neck to get to, but hopefully I won't ever have to touch it again.
The setup I used was a 90 out of the banjo bolt into a needle valve, then ran a braided line out of that, through the firewall and straight into the guage.
coblanchard
Jun 23, 2009 09:53 PM
blacksmoke99
Mar 26, 2009 04:09 PM
Dinner
31
Jan 4, 2008 10:54 PM
buddy26
Dec 20, 2007 02:01 PM
06CTDforAU
15
Jul 17, 2007 03:09 PM
