Frp Mods?
Frp Mods?
Has Anyone Tried Something Like A 10k Mod For The Fords On A Cr?
A 10k Mod Shorts Part Of Fuel Psi Signal To Ground Which Causes Increase In Fuel Psi. Anyone Think This Will Work? Would Like To Increase Frp.
The CR trucks are too sensitive. If you put a 10k resistor across the signal it will set a CEL and throw it into limp mode almost everytime. Now you could switch it but, once you are rolling a 10K would not provide much boost.
The 10k mod on the Fords sort of works but, in reality it is not all that great, it is just free.
If you care to do it just use the middle wire on the rail and have it at it.
Also for a disclaimer, I DO NOT RECOMMEND THIS AND IT COULS CAUSE DAMAGE TO YOUR FRP SENSOR OR CP3 PUMP AND ALL THE OTHER PARTS ON YOUR TRUCK.
tristan21
Jun 19, 2007 04:57 AM
F11Engineer
17
Mar 14, 2003 08:26 AM
