Found This Pre-Turbo Water-Meth Device
Old Jul 5, 2014 | 10:30 AM
EdmontonCanada's Avatar
I thought this was interesting:
http://killerbeeperformance.com/indu...cooling/i-fog/
There is a pretty good document on the website about it, attempting to debunk many of the arguments people have made on the Internet against pre-turbo injection.
I thought an interesting experiment would be to use this device between stages in a compound set up, since there is typically no intercooling between stages.
Old Jul 7, 2014 | 11:31 PM
gilaphreak's Avatar
That's a really interesting article, very informative. Thanks for sharing!
I've been thinking of getting into Water-Meth since I added the EFI. With the extra added power, I'm seeing higher EGTs than before with the little Banks tuner - especially in the 100*+ Oklahoma summer weather. I've yet to do any research on the subject, but those numbers contained within the attached PDF are VERY tempting.
Would this replace conventional water-methanol injection systems that have to be permanently attached to the engine? I get a little nervous when it comes to any kind of permanent modification. Especially something that can't be ordered from a shop that specializes in that kind of work.
Old Jul 8, 2014 | 07:53 PM
I'm not sure I would call it a permanent modification.
One installs the methanol injection nozzles in the intake track at the airhorn… And most aftermarket airhorns already have 1/8 inch NPT holes for things such as these.
If you wanted to remove the standard methanol injection then you could merely install 1/8 inch plugs.
What interested me the most in the writing was not only the debunking of common beliefs, but that injecting pre-turbo can change the turbo map - making the smaller turbo operate like a bigger one.
1RMDave
Apr 8, 2012 07:31 PM
Mike Holmen
Apr 28, 2010 06:50 PM
jdpiii
Jun 19, 2008 07:34 AM
matego
May 21, 2008 02:05 PM
got...DIESEL?
Jan 16, 2006 05:43 PM
