Floor Jacks
Originally Posted by DUK
What is the gross vehicle weight of a 4x4, 3500 Quad w/CTD?
Mine is a long bed SRW. Before I added the Ranch Hand Front End replacement bumper..........mine was weighed in at a set of cat scales at 4560 front axle and 3200 rear axle for a total weight of 7760 lbs. with me, a full tank of fuel, and 5th wheel hitch.
I dont' think I would feel very comfortable with less than a 3 ton jack trying to lift the front end. The Cummins engine alone weighs in the neighborhood of 1000lbs.
Originally Posted by durasmack
What about bottle jacks and jackstands for shop use? any thougts? should be ok if used with jackstands?
Jack
Originally Posted by caltom
I used the under seat jack once. It worked, and that's all the good I can say about it.
I thought my hand was going to fall off turning that **** to unscrew it. Fortunately it finally got it long enough to actually begin jacking. I don't understand why auto makers put the sorriest gizmos in vehicles to use for flat tires. It's bad enough you got a flat, then you have to use the junk they call a jack and tire tools... I guess they want to make a simple flat as miserable as possible.
That quote above is why I bought a jack at wallys. I think they had a 2.5 ton 180 degree swivle handle (pretty cool) in a plastic case for like 19 bucks. That suckers in the tool box and I won't even bother with the one under the seat. Only good it's gonna do is when I need the handle to lower my spare. I know 2.5 ton isn't much but I'll trust it over the one under the seat any day. Like I said there very cheep, even a bottle jack is cheeper and I'd trust that much more than the stock one.
