First Cummins ever, converted from PS
Old Jan 26, 2016 | 06:11 PM
incrediblehulk's Avatar
Hey guys, I recently bought a 2006 2500. I am looking to get a good 5-7 years out of it. I'm not looking to blow the Pistons out and slam 700hp to the wheels. I simply want a little bit more pick up then it currently has. I haul gym equipment and concrete materials for the most part. So it's not like I'm hauling trailers and need a heavy duty transmission, but not opposed to beefing it up a bit either. So off the top of my head I'm looking at head studs, a programmer/tune, I like the sound of a wicked wheel too, and an intake or somethings you guys might suggest. I'm also under the assumption that the 5.9 in 06 didn't have an egr to worry about and that the dpf wasn't introduced until the 6.7??
Old Jan 26, 2016 | 09:01 PM
Equalizer 2's Avatar
Can't talk about any performance upgrades other than a turbo back exhaust but yes the DPF did not choke any 5.9s as it did not get introduced until the 6.7
Old Jan 27, 2016 | 09:12 AM
CRF450R RIDER's Avatar
head studs are a good ideal, but the only thing you need to do is get EFI live and i think that will get you the power you are looking. the wicked wheel doesnt really do anything other then sound, but if sound is all you are looking for, then go for it. stock intake is good to around 500hp, so i would leave it stock and only use stock filters, no k&n filters. changing your exhaust wont really do anything for you either.
Old Jan 27, 2016 | 10:02 AM
Thank you, also 06 didn't have egr either or am I incorrect?
Old Jan 27, 2016 | 10:04 AM
Thank you. I think I'll head stud it and do the EFI, is there anything I need to do to bulletproof it. I've read a lot about common rails needing replaced? Any transmission work you'd suggest?
Old Jan 27, 2016 | 10:07 PM
Can't say anything about the EGR as I have no idea.
Old Feb 1, 2016 | 11:11 AM
soulezoo's Avatar
DTR 1st Sergeant
Congrats on your purchase. The EFI live suggestion is a good one and you can get a mild tune that fits you.
Head studs at the power levels you are looking at are an unnecessary expense. Unless you are going to see 50+ psi out of your turbo, you are GTG. There is a torque sequence available somewhere to get a few more lbft out of the stock bolts and improve what you already have.
The common rail does not need to be replaced. The #4 line sometimes fails and needs replacement. The injectors are perhaps the weakest link.
Do some thread searching here for tranny upgrades. The torque converter being the biggest improvement you could make.
On the whole, you can through the EFI live do about a 100hp increase without having to upgrade anything else. That is subjective on how you use your vehicle and assumes good working order on all parts.
Old Feb 1, 2016 | 11:15 AM
soulezoo's Avatar
DTR 1st Sergeant
Also, the 06 has what is referred to as "in-cylinder" EGR. The cam is made in such a way as to help with EGR and is therefore a little restrictive. An aftermarket cam eliminates that.
I mentioned above the 100hp... if you are looking past that, then there are a host of fuel and turbo and transmission upgrades you will then have to put in place to support that HP.
Old Feb 1, 2016 | 07:58 PM
Thanks for you help 1SG!
Old Feb 2, 2016 | 12:38 AM
FastTaco's Avatar
Like soulezoo said. Studs aren't needed until over 50 psi boost. Get a torque converter, shift kit, and a good 100hp efi live tune. You will be set.
Old Feb 2, 2016 | 05:21 AM
Thank you.
SKATERHAULER
0
Feb 7, 2012 09:20 PM
Wall8053
Introductions / New People
Aug 6, 2009 02:17 PM
Ram1driver
Jul 27, 2009 04:59 PM
GIT-R-DONE
Dec 13, 2007 07:51 PM
xtoyz17
Mar 17, 2007 11:49 PM
