Firering Install
Old Oct 25, 2007 | 02:36 PM
no limit's Avatar
Firering Install
Was is the proper way to install firerings after the head is cut ? ie torqueing and such .Is there anything special used to hold them in place while setting head on?Thanks for any and all help.
Old Oct 25, 2007 | 03:12 PM
WUnderwood's Avatar
is this truck street driven?
Old Oct 25, 2007 | 03:34 PM
no limit's Avatar
yes street driven.
Old Oct 25, 2007 | 05:23 PM
OutOfSight's Avatar
Why on earth do you need fire rings on a daily driven truck? Just studs will hold over 700HP
Old Oct 25, 2007 | 06:24 PM
omaharam's Avatar
Firerings need replaced at least every year.
Old Oct 25, 2007 | 09:30 PM
nobody's Avatar
I was told to use 3M weather strip adhesive(yellow snotty looking stuff). Not real sure about any special torque requirements.
John
Old Oct 25, 2007 | 10:05 PM
desertchecker's Avatar
fire rings need replacement every year ? Omaharam are you speaking from experiance ? I have not heard this before perhaps you can teach us something ? care to explain to all of us why ?
Old Oct 25, 2007 | 10:16 PM
omaharam's Avatar
Well, my person experience would only be that when my head was off and I inquired about getting fireringed along with studs, I was told that firerings have a high tendency to crack (they are steel) and fail and should only be used on a competition truck that will be tore down each season. That was based on multiple trucks having the problem. Never did a search on here or call anyone else, but trust the source. So I went with 0-ringed (smaller diameter and different material) with the studs as advised.
Old Oct 26, 2007 | 01:50 AM
OutOfSight's Avatar
Ive seen alot more head problems with people that have went WITH firerings and Orings, alot less with just studs. Im putting somewhere over 60PSI(probably 70) and never had a problem with just studs, didnt even replace the gasket. Ive also been down the 1/4 over 100 times.
Tow-mater01
Oct 31, 2009 06:06 PM
slimerept
Dec 16, 2008 01:43 PM
QWKRTNU
Sep 26, 2006 10:22 PM
Greeds22
Nov 12, 2005 04:49 PM
turbo lcc
Dec 24, 2003 03:04 PM
