filtration ?
Old Jun 8, 2010 | 10:12 PM
rufushusky's Avatar
Originally Posted by ripping r
well looks like there are a lot better ways to go here and a lot cheaper to. guess i'll keep looking mabey build my own setup. i like the idea of keep ing the stock filter housing for the fuel heater.
A pair of compression to hose bard, -10 O-ring to -6 JIC, -6JIC, a single -10 O-ring union with a pair of BF1311 filter bases and your good to go.
Originally Posted by bansh-eman
Not to mention it is pretty dang hard to beat the fuel/water seperation that is offered in the stock housing.
I completely agree, the PF7977 is an amazing filter.
Old Jun 8, 2010 | 10:30 PM
OldDodgeOwner's Avatar
That's my thinking as well. I got the big line kit to tie in from the stock filter housing, run to the 2mic filter, then to the CP3. Basically the same kit Glacier sells, but $70 cheaper. My lift pump's about shot too, so I'm going to put in a Raptor here shortly. Should have my fuel system all set then.
Old Jun 9, 2010 | 08:39 AM
CD in NM's Avatar
I went with the GDP 2-micron kit off the stock filter housing, using the Baldwin filter in the stock housing, plumbed my FP gauge tap after the 2-micron filter, I have a stock lift pump and am seeing 10#s FP going into the CP3.
I wanted to keep the stock housing because of the water seperation abilities.
I have an AD-150 BNIB sitting in the garage waiting to be installed. I still plan to keep the stock housing in line when I do the AD install. Actually, I would like to also keep the stock LP in tact and make the 2 fuel LP's switchable, that way the stock LP could be like a backup LP just in case I had a problem with the AD. I have to figure out how to configure the 2 together. It would be easy to install a DP switch to control the LP's, the plumbing of the lines is what I need to figure out, probably will need a check valve or two in the lines.
CD
Old Jun 9, 2010 | 07:01 PM
bansh-eman's Avatar
I as well am going to install a Raptor LP once my stocker goes out. Hopefully it's a long way down the road, but we shall see.
easinc
22
Mar 31, 2011 11:22 PM
brillmtb
Jun 6, 2003 07:02 PM
commtrd
15
May 20, 2003 02:06 PM
MCMLV
25
Dec 22, 2002 09:03 PM
