filtration ?
Old Jun 6, 2010 | 05:54 PM
ripping r's Avatar
filtration ?
I thought i had it all figured out. and was going to up grade to an airdog in november when my 5 years is up. but i saw this add in diesel power. ? is can the stock lift pump push fuel through this set up. and the price is very high.
http://xx-fuel.com/OnlineStore/index...&products_id=7
Old Jun 6, 2010 | 06:40 PM
RyeThomas's Avatar
Winner winner chicken dinner!
I would go with a trusted Co like GDP rather than someone I knew very little about. And I was not impressed with their add that talked about nothing but the show quality looks. I want facts on flow and filtration not an add for how great it looks. JMO.
Old Jun 6, 2010 | 06:44 PM
bansh-eman's Avatar
I would be interested to know who the manufacture for the filters are. And wouldn't mind getting my hands on the spec sheets to see how they compare.
Old Jun 6, 2010 | 08:38 PM
johnh's Avatar
if i didn't have a racor 2 micron filter already, iwould go for that one
Old Jun 6, 2010 | 09:31 PM
ripping r's Avatar
ya im not looking for the looks either. but there clamed micron rateing got me thinking. i would also like to see a spec sheet for the filters and know who makes them. i thought cat had the only 2 micron filter. still dont know if the stock in tank pump could push fuel through them tho.
Old Jun 6, 2010 | 10:40 PM
AH64ID's Avatar
They won't give you the Donaldson part numbers, I have asked..
Look at the link in my sig.. Its the same level of filtration as the XX, using GDP parts.
On a side note, the AD overall filtration is less than stock and can be beet by the Baldwin PF7977 in the OE canister.
Old Jun 7, 2010 | 12:25 PM
ddszero's Avatar
AH64ID,
Are you running your stock fuel pump or has it been up graded to push the fuel through the 5 and 2 micor filters.
Thanks
__________________________________________________ _______________
2005 2500 Crew Cab short bed 4x4
NV5600 3.73 With Limited Slip
115,000 Miles, K&N Drop in filter
12K Mile Marker on TRANS4MER MOUNT
BFG KO AT 275/70 R17
Old Jun 7, 2010 | 03:43 PM
AH64ID's Avatar
Yes I have the stock pump. I have been pushing thru 3 filters for 40K miles.
Old Jun 8, 2010 | 08:39 PM
bansh-eman's Avatar
I as well run a stock LP and push through the MK-2 2mic filter and the Baldwin 5 mic in stock location.
Ripping,
Donaldson makes a 2mic ELF7349
Old Jun 8, 2010 | 09:20 PM
OldDodgeOwner's Avatar
I just bought the kit from Vulcan performance. The intake manifold mount, filter, and big line kit were about $145. Came with a Donaldson filter (P551313), supposed to be 2mic, but I figured I can replace it with whatever I want later. Best deal I've found so far.
Old Jun 8, 2010 | 09:44 PM
rufushusky's Avatar
Ripping,
The ELF7349 is a 15 micron oil filter the 2 micron 1-14 fuel filter is the P551313(short) or P551311(long)
Old Jun 8, 2010 | 09:51 PM
ripping r's Avatar
well looks like there are a lot better ways to go here and a lot cheaper to. guess i'll keep looking mabey build my own setup. i like the idea of keep ing the stock filter houseing for the fuel heater.
Old Jun 8, 2010 | 09:53 PM
bansh-eman's Avatar
Sorry... I posted the wrong filter.... The ELF is a oil filter NOT fuel!!!
The 2 mic fuel filter is the P551313 sorry if I confused anyone!
Copied the wrong part number out of my excel file...
Old Jun 8, 2010 | 09:54 PM
bansh-eman's Avatar
Not to mention it is pretty dang hard to beat the fuel/water seperation that is offered in the stock housing.
Old Jun 8, 2010 | 09:58 PM
ripping r's Avatar
I forgot about that to.
