fed up with quadzilla stuff
This is the same reason you can see a mpg gain... your making more hp per drop of fuel burned, so it takes less fuel to make "x" hp.. The gain in efficiency is smaller at the hp demand is lower.. i.e. empty cruising, but as the demand increases, towing, the efficiency in noticed... But one caveat to that, if you drove your pyro with stock programing you will see a MPG decrease, as now you don't run as hot and can drive the road, not the pyro, so your going faster than you were before... But if you just towed in cruise control before and will drive the exact same afterwords then you will see the largest gain... How much is very driver/rig dependent, but the physics is there..
brendangsxr
Nov 21, 2006 04:40 PM
Bradleysram
Apr 28, 2005 12:22 AM
ron717
Feb 18, 2004 10:44 PM
