Fass kit
Hose
FL-1001 for 3/8"
FL-1002 for 1/2"
Both sold by the foot.
Wire Harness:
The one with the relay for 98.5-04.5 trucks -- WH-1002 (NOTE: you can get this harness to work with any application.)
The one without the relay for 94-98 and 05-07 Trucks -- WH-1001
Click here and check out page #6.....
That will give you every part used in a kit for your year truck. ALSO...for the fittings, RM-1002, bolts and such....use this mounting package part number:
MP-A9008
MP-A9008
If you want the items for the HPFP, this is what you will need:
WH-1002
14' FL-1001
THB-1001
BHB-1001
MP-A9009
AND if you have the FASS...you can get the HPFP base and convert it with a part numbers:
AB-1001
OR-031 (O-ring)
6120 (Gasket)
PS-1004 Spring (18 PSI)
This is the adapter base for the HPFP and items to make it work. BUT i would suggest just selling the FASS and using some of that money buying a new HPFP with full wnty and such......
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
Flatty
Apr 25, 2005 12:49 PM
