FASS and FP Question
Old Sep 7, 2008 | 07:25 AM
Jason_K's Avatar
ok, here it goes......i had a fass pump 95gph(pump only) sitting around the garage that was previously used on my 01. well last night i finally got my lazy **** in gear and put it on my 05. before the pump i would see 7psi at idle and it would drop down to 3psi under WOT. now i see 7psi at idle but it doesen't move at all under WOT. does this seem right? obviously the pump is keeping up because the fp doesn't drop whatsoever, but i thought that i would see around 19psi at idle since that's what i was seeing w/ my 01. is there a regulator somewhere that only allows that much pressure to be let to the cp3? sorry for the long post and thanks
jason
Old Sep 8, 2008 | 11:16 AM
Jason_K's Avatar
bump......
Old Sep 8, 2008 | 11:44 AM
Bad Ramer Jamer's Avatar
I don't know if it's the same on a 95,,,but there might be a spring in there somewhere you can change to regulate pressure.
Old Sep 8, 2008 | 11:59 AM
87BRGN's Avatar
If your running an isolator with your fp gauge, make sure its full w/antifreeze.
Last week, mine dropped from 19 at idle to 9. yet wouldn't drop under wot. Thought it might be filter, but checked isolator first and it was low. didnt see any leaks, but it was back to normal after i topped it off.
Old Sep 8, 2008 | 12:34 PM
Jason_K's Avatar
i'll check into that, i just figured that since it was putting out around 20psi on my 01 then it should be putting out 20psi on my 05
that's a good idea and is something i should have checked in the first place. i'm such a thanks
Old Sep 8, 2008 | 02:05 PM
paroxysym's Avatar
actually you can try silicone spray- i used that instead of antifreeze, diesel dan said its good cause it keeps things lubed up. duh! but i would check the line thats hooked to your fp gauge. start with the gauge and work backwards, usually thats the prob
Old Sep 8, 2008 | 03:27 PM
Sorry, I didn't know you were getting 20 psi before.
Old Sep 9, 2008 | 08:04 AM
Jason_K's Avatar
i'll check everything out this weekend, i'm sure it's something little because like i said, my fp doesn't move at all under wot.
no need to apologize, i just kinda threw that in there and should have paid better attention to my wording
ollie32
Jun 3, 2007 09:29 PM
Buckshotmckee
May 23, 2005 12:08 AM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
