Extra FASS Parts, I'm Lost?????
Old Nov 1, 2008 | 08:14 PM
dodgediesel's Avatar
Exclamation Extra FASS Parts, I'm Lost?????
Got my 95/150-1007 FASS for my 07 Ram. All the parts and pieces are there fot the install but I have a spring that was included. What in the world is this spring for. I have NO idea where it belongs and the directions don't say anything about a spring?? The spring is 9/16" wide x 1" long. Anyone know???
Old Nov 1, 2008 | 08:27 PM
dodgezilla04's Avatar
the spring is for increasing the pressure if you need it... you will get 15psi with the pump the way it is.. plenty for most trucks. just put it in a ziplock bag and save it.
Old Nov 1, 2008 | 08:31 PM
bluechrome's Avatar
I used the spring and it gave me about 20psi. I goes in the return side of the pump
Old Nov 1, 2008 | 08:50 PM
Is this normal?? There is a tamperproof lock on the motor body. Is that where it goes and if so, will my warranty still be good if I break that seal?? So the spring that's in there is set at what pressure?? Thanks guys...
Old Nov 1, 2008 | 08:58 PM
bnold's Avatar
The spring is under the nipple that feeds the return line.
Dont break the tamperproof lock as your warranty will be voided
Stock spring should be 14-16psi
other spring 18-20psi
Old Nov 1, 2008 | 09:00 PM
bluechrome's Avatar
Yes do not break that!!!!!
Old Nov 1, 2008 | 09:03 PM
Which spring do you fellas think a guy should go with?? Not running too much in my signature?
Old Nov 1, 2008 | 09:25 PM
Howling's Avatar
Just leave it the way it came,you will be fine.
Old Nov 1, 2008 | 09:37 PM
I'll see how it works with the one it has. I'm a guessing if I put in the stronger one, the pump will get louder???
Old Nov 1, 2008 | 10:05 PM
bnold's Avatar
no.................
Old Nov 2, 2008 | 01:35 AM
Thanks guys for all the help and tips.
nbaggett89
Dec 26, 2015 09:36 AM
Hodges4x4CTD
Sep 19, 2008 07:23 AM
CTD_Neil
Jul 19, 2005 08:13 PM
Diesel-Dan
May 27, 2004 09:40 AM
