New Airdog and wont start
Old Nov 1, 2008 | 07:35 PM
dieselfumes57's Avatar
Just installed new airdog and will not not start. I am getting fuel to the connection port in the cp3 but it wont crank. Does anybody have any idea what could be wrong? One thing in the instruction manuel was talking about capping and removing the old fuel filter canister but i just decided to leave mine there. I wasnt sure where it needed to be capped or what it was talking about on that one. Any help would be greatly appreciated.
Old Nov 1, 2008 | 08:02 PM
tritont's Avatar
just checkin the obvious... did you let it crank for a while a couple different times ? Sometimes it takes a while to build rail psi and fuel psi after having the lines open.
You shouldn't have to remove the existing canister for it to work. Are you getting good psi to the CP3 not just fuel there ? You shouldn't have any extreme bend in the lines of there are any. That can cause cavation in the lines.
Old Nov 1, 2008 | 08:23 PM
53 willys's Avatar
does that mean the engine is not even turning over??? or are you cranking and cranking and it still wont start??
Old Nov 2, 2008 | 07:07 AM
Hvytrkmech's Avatar
Did you fuse tap the trigger wire for the A/D?
Tim
01blackspeeper
Mar 23, 2012 04:52 PM
Tractor Truck
Jan 20, 2011 01:56 AM
quads4_life
May 1, 2010 12:54 PM
4969joes
Mar 18, 2010 10:19 AM
kdbvulcan
20
Dec 6, 2008 04:34 PM
