Exhaust elbow size... 3 3/4"????
Old Jan 2, 2007 | 11:57 AM
ataboy9026's Avatar
I am looking at a stock elbow off a 04 305hp engine. It measures 3 3/4" inside both inlet and outlet. Is this the one that is used on even the 325hp trucks like the 06? Mine is a 03 with the 250 hp engine and I wanted to upgrade the exhaust, just wondered if this is what I need.
Old Jan 2, 2007 | 12:32 PM
ataboy9026's Avatar
I have read that the one for my 03 is 4" in and 3 1/2" out. But does this one that is 4" in/out hook up to my turbo with no mods or is there some newer style clamp/pipe?
Old Jan 2, 2007 | 12:46 PM
Patriot2500's Avatar
PM sent regarding downpipe.
Old Jan 2, 2007 | 01:53 PM
tcr's Avatar
tcr
You can use the same turbo outlet/elbow inlet clamp(if you can get it off w/o damage), but you need the newer 04.5-06 exhaust downpipe clamp. There is 1/2" difference in the outlet of the two elbows. I have an 05 elbow on mine w/ the 04.5-06 Magnaflow 5" system. Also, it is a major PIA to pull the old elbow clamps off, make sure you get new clamps and just use a heavy duty screwdriver to pry off the old clamps off, they are easily damaged if they are on as tight as mine were. Good luck!
Dodgezilla
19
Mar 30, 2009 09:16 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
Hemlockusa
Jan 28, 2006 07:07 AM
