Exhaust & CAI questions
Old Aug 20, 2008 | 03:48 PM
Clane's Avatar
I'm finally getting around to doing the exhaust and intake on my truck but have a few questions before making my decision...I would like to just replace the muffler and leave everything else in place (good / bad choice??)
So I've narrowed down to the Donaldson. What's the difference between the M090535 & M090544 other then the Inlet & Outlet Diameters? Is one louder then the other?
comments, questions, suggestions??..
Question on the intake....
I just ordered an AFE Stage 2 intake with the PG7 filter and was thinking about using an Outerwares over the filter. Anyone else using a prefilter on their open box CAI?
Most of my driving is highway/city.. the only off road use my truck see's is towing the toys to the sand dunes....
thanks for any and all input!
Old Aug 20, 2008 | 03:52 PM
rip 112's Avatar
Pre filter will work fine, and putting just a muffler on will be what most tell you to do, either that or lose it.
Old Aug 20, 2008 | 04:22 PM
RamWheelsBy4's Avatar
Yes the pre-filter is good. Keeps any larger crude from getting on the filter material, keeps most water/snow off of filter material and will make it a lot easier to clean the filter.
Not sure the specific difference on those, but you need 4" inlet/outlet for replacing muffler on your OEM exhaust. And I agree just replacing the muffler with a high flow one is the simplest and cheapest exhaust upgrade.
Old Aug 20, 2008 | 04:35 PM
mpracehemi's Avatar
Do you have state inspections?? Here where I'm at, I don't and when I changed to the 5" t.b. I lost my kitty somehow. I get compliments on how my truck sounds. It's not too loud and I don't have to talk loud to have a conversation either. If interested on how much I paid/where I got it, pm me.
Old Aug 20, 2008 | 10:40 PM
Clane's Avatar
There we go.. thats what im talking about... thanks RamWheels! I use them on the quads, but didnt know if it was over kill on the truck...
You dont happen to have the part number do you?
No inspections, just the yearly smog....
Are you running the Donaldson?
Old Aug 20, 2008 | 11:33 PM
mpracehemi's Avatar
Wow, Nevada has diesel smog laws?? Ca. doesn't til the '07.5 (the 6.7's) and then those trucks will have to be smogged, that's why I didn't buy one. Then reading some of these ppl having some problems with the filter stuff, I'm really glad I didn't buy a new one.
I don't know what brand of muffler that was in my kit except that it was 'high perf.' Inside is 5" through n through w/ louvers. I have roughly 2500 miles on it and still sounds good. I'll be reusing it when I go (black) single stack. I'm going to try no muff. 1st, if too loud I'll put the muff. in.
Old Aug 21, 2008 | 08:11 AM
D-Roc's Avatar
I run a prefilter on my PG7. It quiets it down a little (I don't feel like spending another 400 some odd dollars for the quiet AFE intake). I haven't noticed any power loss from the prefilter...keeps the filter cleaner as well.
part number I use: (yellow AFE prefilter) 28 10031
fits
2490010
2491002
Old Aug 21, 2008 | 08:15 AM
D-Roc's Avatar
THat looks like a yellow filter under the blue prefilter...are you running the PG7?
Old Aug 21, 2008 | 11:24 AM
AH64ID's Avatar
I just ordered a Donaldson M085171 40" 4" for my truck. The kitty is about to its 9th life....
Old Aug 21, 2008 | 02:10 PM
tcr's Avatar
tcr
How are you guys cleaning the oil-less filter? I've got one on the way.
Old Aug 21, 2008 | 11:08 PM
Clane's Avatar
Thanks for the info on the pre filters guys!
Whats the differences between the 40 and the 51? Does being shorter make it louder or did you get that one because of the space it needs to fit into under the truck?
Old Aug 24, 2008 | 05:48 PM
AH64ID's Avatar
Space is one concern, but I have heard the 40 isn't much if any louder... And really I am just going for a little quieter than my current no muffler and kitty setup.
Old Aug 24, 2008 | 07:09 PM
Didn't see the question before. I am running the ProDry S filter now.
Old Aug 24, 2008 | 08:37 PM
D-Roc's Avatar
I like the idea of the Pro Dry...I oil my PG7 perfectly, no over oiling, but I find my prefilter catches a bit of it...no biggie. i might try one of those....
Old Aug 24, 2008 | 10:22 PM
I ran the AFE Stage I for a year plus with the PG7 filter. Cleaned and oiled it a few times. Then went to Stage II with PG7 for street and Standard filter for track. I used a pre-filter on everything except at the track. The PG7 filtered fine and I had two PG7 filters, so cleaning was not too much of a hassle. I always had a clean one ready to go on. The ProDry S seems to be a good option for me. I do believe that it flow more air than the PG7, but my white glove test when I take it off to check or clean shows pretty much the same filtering for my conditions as the PG7. No dirt/dust in the intake behind the filter. Cleaning is the same, just don't have to oil which is the pain.
Mydogstruck
0
Feb 19, 2013 11:50 PM
6.7L MegaCab
Nov 14, 2011 04:01 AM
Bowser50
Jul 28, 2010 04:02 PM
DirtEater
Dec 1, 2005 08:49 PM
2k3 ctd
Apr 11, 2005 02:48 PM
