Engine difference?
Old Mar 24, 2005 | 10:08 AM
Reel Native's Avatar
Engine difference?
I have noticed that there have been a few questions about a H.O. engine. I just purchased a 05 3500 and now I wonder which engine I have, are there 2 different engines and if so how do you tell them apart.
Thanks in advance
Old Mar 24, 2005 | 10:23 AM
Gadgetman's Avatar
2005 Engines are all HO in all 50 states...
Old Mar 24, 2005 | 10:26 AM
RamWheelsBy4's Avatar
Well I'll give you what I know about HO/SO.
Dodge/Cummins in early 2004 released the 325/600HO(High Output) Cummins in the 2500/3500 Ram trucks(These commonly referred to as 2004.5). This was to be able to sell one diesel engine configuration in all 50 states and meet EPA/Emission requirements.
Before this there were a number of different Cummins configurations SO(Standard Output), HO(High Output), California verisions with Catalytic Converters, I think there were a couple other areas that also required specific configurations to meet local Emission Regulations. They had different HP and Torque specs along with area specific equipment and programming.
I believe that since the 2004.5 release that all are normally HO engines. Yours should be a 325/610 HO Cummins. Should say on the Window Sticker or truck invoice sheet.
Old Mar 24, 2005 | 10:39 AM
Tom488's Avatar
Limiting this discussion to the Common Rail engines only:
2003 S.O. Federal Emissions: 250HP/460lb.ft. Available with NV4500 or 47RE
2003 S.O. CA Emissions: 235HP/460lb.ft. Available with NV4500 or 47RE
2003 H.O. Federal Emissions: 305HP/555lb.ft. Initially only available with NV5600
2003.5 HO Federal Emissions: 305HP/555lb.ft. Available with either NV5600 or 48RE
2004 mirrored the 2003 options, except the 47RE was replaced with the 48RE in all combinations
2004.5 introduced the Cummins 600 engine, which carried 50-state emissions. It was rated at 325HP/600lb.ft., and was available with either the 48RE or the NV5600
2005 brought the 610 engine into being, with 325HP/610lb.ft. Also 50-state legal.
2005.5 (as of January) saw the NV5600 replaced with the G56 6spd manual gearbox.
Old Mar 24, 2005 | 11:24 AM
HorseHauler's Avatar
don't forget that in 2003 the 48RE was available to the SO (250/460) engine as of Jan 1, 2003
this is what i have...
Old Mar 24, 2005 | 12:00 PM
4X4 HULK's Avatar
And I have 2003 with the 48RE in the SO (235/460).
Old Mar 24, 2005 | 03:01 PM
Tom488's Avatar
Right - sorry about that... the 48RE replaced the 47RE in the '03.5 model year - shortly after the 48RE became available
Old Mar 25, 2005 | 09:14 AM
Thanks for all the replies
j_k_auto
Aug 8, 2007 10:14 AM
riffman
Jul 14, 2007 10:31 PM
NHDiesel
Jan 20, 2006 11:34 PM
rico334
Oct 13, 2004 07:21 PM
jarmar
Feb 18, 2004 11:07 PM
