Auto/manual engine difference?
Old Jan 20, 2006 | 09:59 AM
NHDiesel's Avatar
What exactly is different between the auto and manual trucks that give '96-'98 manual trucks 20 ft-lb. more torque? I'm sure its just a small thing, like fuel plate profile or adjustment, but I was just curious which adjustment or part was different.
Jim
Old Jan 20, 2006 | 01:34 PM
robert chilton's Avatar
Different injector pump. Yours should have a 180 pump not the 215. Injectors may also be different.
Old Jan 20, 2006 | 01:39 PM
TxDiesel007's Avatar
Delivery valves
on the IP should also differ... as well as the dana 80/70 rear ends
Tx
Old Jan 20, 2006 | 02:16 PM
gunracer1's Avatar
the funny thing is how well a set of 215 injectors wake up any of the sub 200 hp motors. like to the tune of 40 rwhp.
Old Jan 20, 2006 | 03:26 PM
mrwaters's Avatar
The turbos are different,
215 engines take its wastegate pressure from across the engine on the afc housing
180 engines take it at the turbo outlet flange.
Old Jan 20, 2006 | 03:36 PM
gunracer1's Avatar
the turbos are really the same, just the wastegate is set at a lower pressure on smaller hp motors. 215s usally boost 24 to 25 psi stock.
Old Jan 20, 2006 | 11:34 PM
ratsun's Avatar
___________________________________
How come when you add the stuff the 215 has to the 180 it gains more then the 35hp between the two? Like the bigger sticks and DVs dont you add closer to 50hp? Was the 215 under rated?
td3620
Feb 10, 2014 10:02 PM
Bookshelf
May 18, 2011 04:20 PM
tool
Apr 3, 2010 11:45 AM
rusty1161
Apr 30, 2006 09:40 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
