Edge on level 5 hesitating at half throttle????
I have an edge on my 5.9 truck with an auto tranny. Its the hot version. When im about half throttle accelerating it hesitates really bad. It feels like im pumping the gas pedal (maybe even worse). It actually seems like the motor is cutting out a bit. It doesnt happen on any other level then 5. Any ideas?
Well the truck sat for 6 months without being drivin. The fuel filter should be changed.. I think I want to change that first. I dont have a rail pressure gauge to check the lift pump. I guess when I bring it to dodge for that new recall out ill have it checked. It doesnt happen on any level other then 5.. Even on level 4 it doesnt happen. Not at all. On level 5 its fine if you go wot. 40psi of boost its still hitting. I would think if the truck didnt have enough fuel pressure it would cut boost too.
i had that problem with my edge on my 04.5... it wasnt as bad you yours sounds like... it was just a slight hiccup... sold the edge and got a PPE and now it runs soooo much better... i know it was the edge and i called edge and they said it was going to cost me to get it fixed.... i was like eff that and sold it
Ranger391
Jul 5, 2010 06:54 PM
offroadcpa
Feb 17, 2009 06:22 PM
airplaneman00
Mar 26, 2007 10:34 PM
