Dually tire valves
Dually tire valves
Hey guys,
After several frustating times incidents dealing with tire pressure I wanted to see if there was an easier way to reach the stems. I looked into the extensions, but read several negative comments about them here, so that was that. After various keyword searches on Google, I came across this place:
http://www.ridgecrest.ca.us/~tire-man/kit3.html
They sell what appears to be the perfect solution for duallies...has anyone tried/heard of them?
I wouldn't use them. You cannot rotate the tires without removing and reinstalling the stems. Which in the case of these units requires you to unbead the tire from the rim each time you move them from one rim to another. I just use a standard two headed tire guage and chuck.
No problems airing up and checking the preasure.
Bobcat698
09-12-2006 08:36 AM
CTD NUT
09-12-2005 04:40 PM
RobG
09-05-2003 09:13 AM
patriot pearl blue
12-09-2002 08:53 AM
