Dual fueler or GDP
Sorry guys, yes PPE dual fueler. Such as your stock CP3 and a modded one.
Smoke, so you have to run an aux fuel system from the tank as well as the dual fueler? I thought your could run the fueler rather than the GDP set up. Not to familer with the systems as you see
that is correct you have to have a lift pump GDP ...... In order to use a Dual CP3 ( High Pressure Pump Setup) .... Your truck has both now just the lift pump in your truck wont flow what a GDP or Fass etc. will
old smokey has a DIY cp3. NOT dual fueler.
diy is single stock cp3 that has had the fca and gear pump inlet/outlet ports modified. it isnt even equivalent to a stage 1 modded pump.
The PPE dual fueler does not like high feed pressure. Between 15-19lbs seems to be what works for me. I run 2 walbro's with one being on a toggle switch. My feed pressure and volume was down big time this a result of having a modded pump on the bottom. I needed a second pump to maintain that 15-19 feed pressure.
The boss would be ideal, it flows based on engine rpm I think....
onetun
onetun
RyeThomas
15
09-17-2007 03:32 PM
3500_CTD
06-12-2007 06:22 PM
PourinDiesel
65
05-09-2007 01:11 AM
Timinva
80
12-31-2006 07:06 PM
