Draining The Rail
Old Mar 15, 2009 | 08:14 PM
ronc's Avatar
Draining The Rail
When you drain the rail what happens, symptoms that is, does the truck cut out?
Old Mar 15, 2009 | 08:28 PM
Townsend600's Avatar
Yep. Try to keep it to a minimum. Unless you feel like destroying your injectors, lift pump, and injection pump, along with the possibility of burning a hole in a piston.
it pops, and cuts out. Like a quick repetitive studder. Did you drain the rail with the smarty JR?
Old Mar 15, 2009 | 09:11 PM
ronc's Avatar
I guess, it also happenened with a Triple Dog. Truck cuts out and pops when romped on at low rpm. Thats what i needed to know. thanks.
Old Mar 15, 2009 | 10:42 PM
phantom 309's Avatar
how can you tell if you drained your rail? what causes it?
Old Mar 16, 2009 | 12:35 AM
White97GTVert's Avatar
The noise it makes is startling if you haven't heard it before. When it happened to me a long long time ago I thought I blew the thing up. That was in 2005 though. Courtesy of a very hard fueling TST and non-modded pump. I say again, that noise is shocking.
Old Mar 16, 2009 | 01:13 AM
RamsMountain's Avatar
I used to experience this but not like explained above. Mine was like a miss in my highest gear pulling extremely hard. Kind of like a bad spark plug missing some. I never heard much but could feel it.
I no longer have the problem after installing a second cp3.
Old Mar 16, 2009 | 07:34 AM
The only box that my truck ever did it with was the TST.
sallyman1
Feb 14, 2009 12:30 AM
Striper
May 9, 2008 03:13 PM
5.9Excursion
Mar 13, 2008 10:56 AM
RunninLean
Jun 12, 2007 05:35 PM
hoehand
15
Mar 24, 2006 12:46 PM
