Downsides to upgraded in-tank lift pump concerning performance
Old Feb 14, 2008 | 02:41 PM
precision1's Avatar
I think my factory lift pump is dying and I am considering having it replaced under warranty with the in tank pump.
My question is how much can the in-tank pump take, I will have exhaust intake and a Smarty.
Will the pump handle that or should I just go to a FASS or Walbro??
Old Feb 14, 2008 | 03:27 PM
CTD NUT's Avatar
The Smarty is the big variable there. Most readily softwares would be ok with the in tank LP but some of these betas and this new 230 hp tune will pull more fuel than the stocker will deliver. And if you stack anything with the Smarty later, you will need to upgrade the LP for sure.
Old Feb 14, 2008 | 03:44 PM
bluechrome's Avatar
My stock Lp made 505 on the dyno had it for 50k with no prob
Old Feb 14, 2008 | 06:02 PM
trx's Avatar
trx
if your warranty will pay for it i'd go with the stock one for now and change it out when your performance needs change, if you have a fuel guage you will know when that is.
Old Feb 14, 2008 | 06:58 PM
bekim's Avatar
I second the "take the freebie" opinion. I did at 20,000mi and it's running strong at 85,000 at zero cost to me.
Mike
Old Feb 16, 2008 | 12:48 PM
precision1's Avatar
Thanks Guys!! I am going to drop off the truck on Monday
17
Sep 7, 2007 05:38 PM
meddy
Aug 11, 2007 07:43 AM
riffman
Jul 14, 2007 10:31 PM
pred
Oct 17, 2006 06:49 PM
jlells01
Nov 6, 2004 04:00 AM
