Snowperformance stage ll ?downsides?
Old Oct 16, 2006 | 12:32 PM
pred's Avatar
I installed my snow stage ll system, and WOW what a difference,,, But shortly after i noticed an odd smell,,, It was the injector gasket leaking just a bit on all 6 injectors, So i snugged them all down, they were loose,, Now no more leaks,,, Then two + week later, I noticed valve clatter when the snow system kicked in, Especially loud under full power,,, Now i adjusted the valves, they were all a bit loose, 1/2 to 1 turn on each, All is quiet and happy now!!!
Is this what is to be expected when all the carbon is removed from an engine with 300+ k miles????
I am very happy with the new (mod),
Peter.
Old Oct 16, 2006 | 01:54 PM
flashgordon's Avatar
Peter.
I don't thing that the snow stage II had any thing to do with it, ether then you started to lissing more carefully to you eng., with the new system on!
Old Oct 16, 2006 | 04:52 PM
BC847's Avatar
1st Generation Admin
I think it's possible the peak combustion pressures are up at WOT.
So have you turned up the fuel screw a bit along with the fog?
Old Oct 17, 2006 | 06:38 PM
pred's Avatar
My truck responded very well to turning up the fuel screw, I got nearly 6 full turns before runaway, My baby H1C was turning 40+ lbs boost from the fuel i was getting with the stock injectors, I bumped the timing, and it dropped to about 30+ again, with the H2O meth all the way up, I can still hit some 42+ lbs,, I just need to watch what i am doing for now, egt's are still managable, will hit about 15 on #2 fully pegged, with the water meth, I cant get aboue 1350 or so, But i can get real good power under 1000k.
Peter.
Old Oct 17, 2006 | 06:49 PM
BC847's Avatar
What strenght mix (%) are you running?
precision1
Feb 16, 2008 12:48 PM
2007 5.9
17
Sep 7, 2007 05:38 PM
meddy
Aug 11, 2007 07:43 AM
timb
Aug 19, 2005 10:16 PM
jlells01
Nov 6, 2004 04:00 AM
