Does anyone have pics or know a link for a "how to" for a 3 gauge pod
Old Nov 26, 2008 | 12:32 PM
XXLTEXAN's Avatar
I was looking at Diesel Manors sale on that 3 gauge pod and thought it would be a good Christmas present for myself. It has egt, boost (30 or 60) and tranny temp. I am buying a dd pan with a sender port soon so thats easy but how hard is it/how do I hook up the pyro and boost. All help and pictures are much appreciated. Thanks again and Happy Turkey/Football Day!
Old Nov 26, 2008 | 01:17 PM
hoffdog's Avatar
I bought my 2 gauge pod Egt and boost from diesel manor the instructions are very good and I was able to complete the entire deal in about 2 hours
Old Nov 26, 2008 | 02:14 PM
megacabdad's Avatar
Maybe you already saw this...
But if not...
http://dieselmanor.com/diy/CMS3-gaug...ugeinstall.htm
Happy Turkey Day to you!
Old Nov 26, 2008 | 02:54 PM
enafzige's Avatar
Here ya go...
http://www.turbodieselregister.com/f...-write-up.html
--Eric
Old Nov 26, 2008 | 05:44 PM
XXLTEXAN's Avatar
awsome info guys...looks easy enough if I didn't have ogre sized hands. Ya'll have a great Dallas Cowboys Game I mean Thanksgiving!
Old Nov 26, 2008 | 06:29 PM
Pooter's Avatar
The pyro isnt too bad, easiet way is to pull the passenger inner fender plastic(if you have one) and drill the side of the exhaust manifold thru the fender well opending(if you have a lift, dont bother pulling the wheel) if you dont, might make it easier to pull the wheel.
For the boost guage, I just bought the boost bolt from diesel manor, really is pretty easy, pull a factory bolt on the manifold, then replace with the boost bolt(be careful not to torque it down too much and break if off)
For the trans temp sender, I also bought their hot-line tap so I can get the hotest reading from the trans fluid, it was pretty easy to swap out too, just a little messy on your back getting a little bit of trans fluid in your face/ear
Diesel manor also has info on which wire to tap for the guage lights, and also which one to tap for keyed hot (trans temp/egt)
I just made my own little harness for keyed hot, light pwr, and grounds for the three guages in the pillar, then ran them down to each point for power/ground
Give me a shout if you have any problems, might be able to help you out
Old Nov 26, 2008 | 10:26 PM
twoforme2's Avatar
WOW! That is the understatement of a lifetime, it took three showers to quit smelling like trannyfluid.
Old Nov 26, 2008 | 10:49 PM
torkmnstr's Avatar
I have the hot line for tranny as well and man was that easy! But no as easy as the boost bolt. Not to highjack, but have any of you guys had a problem with the boost bolt? Mine boost line has come out numerous times, it seem I can get the nut to tighten enough to hold the line in. Not to much greif please, HA but I put a dab of superglue on it to keep it in place. But I think I might need a new lock nut or something, whew sorry for the long winded jack! HA
Old Nov 27, 2008 | 10:12 AM
BossHogg's Avatar
Make sure and get the full sweep trans guage, because my short sweep spotlights pretty bad as you've seen. The install was a little easier on mine because I already had the pyro tapped. The rest is pretty easy, especially the boost. The trans wires you'd just have to tie up and just keep the sender in the box for now. Pretty simple, just takes time.
Now you'd probably have to pay me to help install your gauges, simply because when I helped install your AFE inatke you spit Copenhagen on me when I was under your truck numerous times! Yes, when you spit from 6'-8" up, the dip spit definately splashes a few feet away where someone might be laying.....and yes I still owe you a punch in the stomach!
Old Nov 28, 2008 | 02:20 PM
XXLTEXAN's Avatar
Fair enough BOSS...when you're right you"re right
Old Nov 28, 2008 | 03:03 PM
ClayBob's Avatar
Happy to offer up my Seahawks for your Thanksgiving feast!
Old Nov 28, 2008 | 04:38 PM
Matt400's Avatar
I did a post some time ago about that pod, check here.
If I were to do it again I would either do it the same or go back to a SPA dual gauge in the SRT A pillar spot which I had on another truck. The DG210 gauge works well for EGT/Trans temp. You get to select high level warning points to flash the LED at you plus it has a recall function for highest level obtained. For example.. if you zero it out you can see what the highest temp was during your trip.
It also has an output that will allow you to use the EGT gauge as a cool down timer. More on that here.
I don't feel the need for a boost gauge but am sure it could come in handy if I had low power & smoke I could look at the gauge and confirm there is a boost issue otherwise I hardly ever look at it.
Old Nov 28, 2008 | 07:46 PM
XLR8R's Avatar
Dang, thanks for the co-wrenching heads-up Kevin!
Blaine's after me to help with his gauges, now I know to bring my Tyvek hazmat suit...
he could have worse habits, though - don't ya hate the drunks whizzing & chumming on the tires of the truck you're working under after dark?
Old Nov 30, 2008 | 11:14 AM
BossHogg's Avatar
Never had that problem, just the copenhagen! LOL
mudman78
Oct 8, 2016 07:08 PM
vwjunkie53
Oct 31, 2007 10:00 AM
j
Mar 22, 2007 01:08 PM
carcrz
Aug 26, 2006 10:30 PM
Txwelder
May 21, 2005 12:48 PM
