Do bigger injectors lower rail pressure?
Old Nov 24, 2004 | 12:30 AM
HO Cummins's Avatar
Everytime i hammer my truck I see the rail pressure go over 27000 and I pray that the safety valve on the rail doesn't blow.
Would bigger injectors lower the rail pressure? If so, which would do a better job, extrude honed or EDM's?
Thanks
Dave
Old Nov 24, 2004 | 03:38 AM
Dodgezilla's Avatar
How do you see the rail pressure?????
Old Nov 24, 2004 | 09:28 AM
Don M's Avatar
DTR Advertiser
Yes, they lower the pressure. Depending on how large they are.
Old Nov 24, 2004 | 09:39 AM
Original Junior's Avatar
Yeah, how are you measuring rail pressure?
Old Nov 24, 2004 | 10:08 AM
Lightman's Avatar
The bullydog outlook monitor displays rail pressure, that's what I'm assuming they are using...
Old Nov 24, 2004 | 10:24 AM
PourinDiesel's Avatar
What is max safe pressure?
Old Nov 24, 2004 | 11:05 AM
Diese's Avatar
isnt it like 35,000 max?
Old Nov 24, 2004 | 11:26 AM
Agades's Avatar
heard it blows at 29000
would like to hear from someone who really knows
Old Nov 24, 2004 | 11:49 AM
HO Cummins's Avatar
I am pretty sure 23,200 is max STOCK rail pressure (1600 bar).
As far as max rail pressure before the safety valve blows, I have always read it to be 27000-29000 psi. I am pretty sure back in late 02-03 when dodge was making a big deal about the commin rail setup, bosch said they designed the system to be able to sustain 27000 psi, but after that the safety valve will open.
BTW I am using the bullydog outlook to monitor rail pressure
dave
Old Nov 24, 2004 | 02:46 PM
JamesP's Avatar
HO,
What are you running that gives you 27K? power pup on extreme? 6-gun/speedloader? EZ on 6?
Old Nov 24, 2004 | 03:08 PM
HO Cummins's Avatar
powerpup: extreme
edge ez 5 (equal to 6 on old EZ)
With the powerpup I think you can also choose to load it as if you have another box stacked with it, however I loaded it as no other box stacked to squeeze out a few more ponies
in other words I have them both maxed out
Old Nov 24, 2004 | 04:16 PM
Cold Diesel's Avatar
Yikes
Old Nov 24, 2004 | 04:50 PM
JamesP's Avatar
I wouldn't be a bit surprised if your at something closer to 28K+ since the EZ is fibbing to the computer.
I wonder if the Outlook takes the rail pressure increase out of the pup when you set it up for "stacked"?
Old Nov 24, 2004 | 05:07 PM
BEHRMAN's Avatar
HO- Do you have a clutch left? Did you upgrade it?
Old Nov 24, 2004 | 06:22 PM
hoot's Avatar
I think the relief valve unseats around 27,500 psi
