DIY Twins
Old Jan 27, 2007 | 12:06 PM
OldSmokey's Avatar
DIY Twins
I found an h2e turbo for cheap and im just wondering if anyone knows where I might get all the piping from. I dont know much about twins setups, Ive looked at the artic air twins and want to so something similar using the stock turbo. Is the h2e a good turbo for twins, what would be a better set up? Thanks for any info. Joel
Old Jan 27, 2007 | 12:39 PM
WUnderwood's Avatar
I think a h2e is a little small for the bottom turbo; how much HP do you want?
Old Jan 27, 2007 | 12:42 PM
05SilverBULLET's Avatar
its a little too small for a bottom turbo... the exhaust side is small.. not the AR, but the turbine wheel itself. they will kick *** for towing( fast response), but probably wont make as much power as other twins.
Old Jan 27, 2007 | 12:47 PM
OldSmokey's Avatar
I want somewhere around 550 hp or so. I will be adding some water/meth injection as well. I would go with a big single, but ive found some turbos like the h2e or ht3b for around $300 and was wondering if i could make a twins setup for less that it would cost for a big single.
Old Jan 27, 2007 | 08:26 PM
Leadfoot's Avatar
Rip has all kinds of flanges and fittings to build twins, very nice guy also.
http://www.sourceautomotive.biz/twin_turbo_parts.htm
Old Jan 28, 2007 | 02:39 PM
OldSmokey's Avatar
Thanks Leadfoot. Does anyone have a list of what to order? Thanks Joel
Old Jan 28, 2007 | 02:45 PM
BigBlue's Avatar
A 3b would be a nice turbo to stack underneath your stocker.
Old Jan 28, 2007 | 02:50 PM
OldSmokey's Avatar
Thats kinda what ive been reading seems like that a ht3b is the way to go.
Old Jan 31, 2007 | 09:58 PM
Leadfoot's Avatar
I thought the trend was going toward the B2. It seems to me like the B2 is cheap and very functional with many sets out there running great. I am leaning toward a B2 under my SPS 62. Let me know which way you go. Please post pictures when you start your build. Good luck.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
subspd
Aug 27, 2006 02:17 PM
