crazy larry vs tst..dyno speaks
well strapped the truck down today and although i feel the motor will get more hp with more mileage this is what i found...the crazy larry with a va 3.1 only put out417 and 761 w/va on the low settting,swithced to va high and went 432 and 768.egts only went to 650 post turbo....next i took out the pup and ran the tst on 7-7 with the va on low and made468 and 833,the i ran the tst bumped to 8-8 and went 469 and836....cwith max post egt and 800.now for some info the crazy larry is much faster on the street strip than the tst.i dont have the stock fuel system changed but will be dropping the tank this week to figure out a new fuel pick up and pump system and run a larger line to the pump.also although i was told it wouldnt on the crazy larry on the street it runs much smother on the shifts,and i noticed today on the dyno that it runs the rpms up to to almost 3500 were as the tstdrops off at 3150...and the larry tune raises the top speed to over 120 mph,but there is a slight bump around 105-108..the tst cuts out at 105-108.the new advance diesel cat 4 turbo kept the egts down very low for me,i was only running 40 psi but can get more when i get a better intercooler.lag time is very minute and there is no noticeable noise difference between the cat 4 and stock...more to come....
Re: crazy larry vs tst..dyno speaks
Originally posted by king d
,and i noticed today on the dyno that it runs the rpms up to to almost 3500 were as the tstdrops off at 3150...and the larry tune raises the top speed to over 120 mph,but there is a slight bump around 105-108.......
I noticed the higher revving too. It pulls hard to 3500, but I thought the crazy larry would've dynoed higher than that. I wonder if crashcade has done anything else to dyno at 498rwhp.
King d, do you have 3.73s?
Did you stack the VA with the TST during the dyno runs?
Also was the did power increase or carry to 3500rpms with the crazy larry program?
Picture of the dyno sheets would be nice if you could provide them.
CLDL Dyno Results
I'd have to say there is something wrong. There have been numerous dyno runs for the BDDL in the low 400's. I'm messing with the CLDL right now and have had the BDDL and there is no comparison. Our local dyno has been ruffed up a bit lately so I can't help you all with this issue.
What was more impressive then the numbers king d put down was how quiet his truck was at those numbers. The set up right now is definitely a sleeper. If I did not see the dyno run I would never have guessed he was putting that much power to the ground. I am going to try the VA with my TST because I was very impressed at the over all power curve that was sustained. Good job Jess
Thom
Thom
not realy sure about the specifics being let out ,i got it from doug at Advance Diesel Technology.it is what he calls a cat 4 turbo.bigger wheel but small housing so spool time is almost stock.major drop in egts.it was a rather big PITFA to put on but the end results seem to be worth while.turbo is sposed tomake 70 psi of boost and take a big hit of nos when it all gets set up to optimal perfromance
MOJO1
18
Mar 23, 2016 06:47 PM
smoky05
22
Nov 30, 2007 08:26 PM
huntingdeer
Sep 17, 2007 09:34 PM
HeberRam
Mar 30, 2007 05:37 PM
Snojumper
34
Mar 18, 2007 12:27 PM
