crazy larry question
Old Dec 1, 2007 | 10:39 PM
ziggy's Avatar
I've got an 04 (pre) 5.9L running Crazy Larry. This motor is supposed to come stock 305hp and around 600ft lb torque from what I've read. Crazy larry is supposed to be 180-230hp and around 300ft lb boost. Can someone verify these numbers are correct, or tell me if you've found more accurate numbers. I'd like to get this dyno'd just to know....
thanks
(p.s. everything else is stock, so pretty easy to guess)
Old Dec 2, 2007 | 01:12 AM
RAT_03's Avatar
DTR's "Secret Agent"
Pretty sure the crazy larry will not work with your truck. It will download into your truck but it will be not be crazy larry since its before 04.5
Old Dec 2, 2007 | 11:44 AM
ziggy's Avatar
I've been running it for a month now.. what do you mean not work?
Old Dec 4, 2007 | 10:41 PM
SMOKIN-U's Avatar
version 2.4.1 will work on all common rails i believe
Old Dec 4, 2007 | 11:22 PM
CReed's Avatar
Version 2.4.1 is the current crazy larry and will work on 03-07 5.9L CR vehicles. Most have been seeing around 450-475 with just the Crazy larry tune alone. Of course exhaust, intake, boost foolers were used in a few of these.
Old Dec 5, 2007 | 07:14 AM
ziggy's Avatar
kewl, thanks... being new.. what are boost foolers?
Old Dec 5, 2007 | 10:33 PM
smoky05's Avatar
a boost fooler tricks you computer into thinking that you are running less boost then you actually are, allowing you to run alot more boost. i have one on my truck and i love it.
Old Dec 6, 2007 | 07:06 AM
ziggy's Avatar
so it along with my TD will work together for the good of all people? (or maybe just me)
Old Dec 7, 2007 | 07:23 PM
SMOKIN-U's Avatar
yes they will be fine
Old Dec 7, 2007 | 09:43 PM
ziggy's Avatar
thanks.. i actually just read in another thread that with my truck (04 pre), i can crimp the wastegate line and boost fool it the cheap way.. know of any good tutorials on it?
Old Dec 7, 2007 | 11:04 PM
SMOKIN-U's Avatar
not off hand i dont, but someone surely will know where you can read up on it
Old Dec 7, 2007 | 11:24 PM
cgmorgan06's Avatar
I dont think that acts as a boost fooler. Crimping the line would be similar to adding a boost elbow, and allowing more boost.. If this is done, a boost fooler is still needed.
Old Dec 8, 2007 | 06:09 AM
ziggy's Avatar
darn... i have much to learn...
Old Dec 8, 2007 | 07:53 PM
CReed's Avatar
Crimping that line only allows your turbo to become non wastegated and I wouldnt recomend this. You can pick one up from quad for around $75.
MOJO1
18
Mar 23, 2016 06:47 PM
smoky05
22
Nov 30, 2007 08:26 PM
huntingdeer
Sep 17, 2007 09:34 PM
HeberRam
Mar 30, 2007 05:37 PM
Snojumper
34
Mar 18, 2007 12:27 PM
