crankcase vent tube.??
Okay so i have an 06 5.9 3500 a little over 25000miles.now my problem is that it has excessive blow by and throws out tons of smoke. Also leaking oul around 1 gallon every 40-50 mikes. Help!
25k miles!!!!! That's it?? Sounds like something BAD is wrong. Excessive blow-by generally stems from broken piston rings. Where is the oil leaking from??
Have you checked to see if you're making oil...i.e. injectors cracked causing fuel dilution? If it's lost power and has the blow-by you described then you've lost compression. The '06 model year, I have read, was bad about cracked rings.
DTR member "BigIron" really seems to know his stuff......he'll probably chime in on this one!!
DTR 1st Sergeant
Friend, if you have to ask that question I am pretty certain you should have this professionally done. You could have a leak down test done ahead of time which is a lot cheaper and point to whether it is necessary to pull the head. A contribution test could be done to isolate the problem cylinder too.
Both of those tests are cheaper than the cost of a new headgasket even if you did it yourself.
Not trying to bash you in anyway but be helpful.
Doj Dewd
15
03-02-2009 07:32 AM
Dodge Trucker
11-18-2006 12:23 PM
skypilot
12-19-2004 12:59 PM
