Commander/x2 Hook Up
if you got the new harness all you need to hook up on your 06 is the coolant sensor, MAP sensor and Rail sensor....then plug the commander into the spades on the X2 harness at each sensor.....the data link is not used..
I dont know how the old harness hooks up I only have experience with the new one...the 06's dont have a data link so I say hook all the rest of them up the same way it was before....I guess you have to use the wire taps for the commander??? I dont think the old harness has spades built into it like the new harness.
i hooked up x2 per instructions minus control pod. started the truck to drill egt sensor. water in fuel light, tranny light and very ruff idle. pushed skinny with finger an almost to the floor before i got a response.
Big T
Jun 14, 2007 07:31 PM
Lost Lake
Mar 18, 2007 02:35 PM
stock03
Nov 9, 2006 11:27 PM
Dodgezilla
Mar 12, 2003 01:50 PM
admin
27
Nov 12, 2002 04:47 PM
