Commander problems
Old Jul 14, 2007 | 04:55 PM
turbopilot51's Avatar
Commander problems
I finished installing my Quad Commander today and it worked great at first. When I went back later to take pics, now the screen is messed up. It won't even dispaly all the pixels and freezes up. Now what?
Old Jul 14, 2007 | 04:59 PM
rjm022's Avatar
had the same problem- you'll need to send it in. when you call them ask for Roark in the tech dept.
Old Jul 14, 2007 | 05:26 PM
TX_Diesel's Avatar
What turned out to be the problem? I was going to order a commander today...
Old Jul 14, 2007 | 05:33 PM
cameroneod's Avatar
If you dont get it worked out, let me know. I've got a bullydog outlook you can have. That goes for anyone else needing guages too. I ended up going with analog because I couldnt stand the flickering numbers.
Old Jul 17, 2007 | 09:45 PM
I called tech support and now my Commander is on it's way back to Quadzilla. They will either fix the problem or send me another unit. I was told some of the older units had screen problems. This is a bummer since I bought the Commander to use while I tow my trailer to Yellowstone next week. Analog gauges are sounding better all the time!
Old Jul 17, 2007 | 09:57 PM
TX_Diesel's Avatar
Oh crap. I just ordered one today, hope this isn't a trend... :-(
Old Jul 18, 2007 | 12:04 AM
qzilla's Avatar
To say that the older units had screen problems is not really true.
Before the big backorder we had some displays that were raised slightly as I mentioned in another thread. I would say that it was caught and stopped before any number of them were sent out. We do know a few of them went out but, we ship so many we are not 100% positive where the issue started. All I know is that very rarely do we get one back that has that problem.
If it is the problem it is a slam dunk fix and is sort of dumb luck that at this stage in the game that you got one. You would have had to get one from someone that had it stuck way back on the shelf. That group of Commanders was a couple thousand ago.
Also, I betcha $1 that we get you going before your trip.
Old Jul 18, 2007 | 08:30 AM
AkitaSumo's Avatar
Sounds like Quad just a made a personal trip to UPS this morning... Now that is customer service!
Old Jul 24, 2007 | 09:10 PM
I got my replacement Commander today and slammed it in. About 20 minuets and I was back up and running. So far everthing is as it should. Thanks to Quadzilla Tech support for getting it here before my big trip to Yellowstone tomorow. The only thing missing now is maybe a Quad tow module!
Old Jul 24, 2007 | 09:29 PM
TexMexCowboy's Avatar
I have a Commander i have not had any problems with it at all. It has been great so far.
Old Nov 21, 2007 | 08:58 PM
quickie's Avatar
I have several issues...... my trans temp displays 300 all the time. the rpm doesnt work. it wont control the edge juice.......... and to think i just today ordered the xzt to replace my juice (before install finished) and a complete unit commander and chip for my 06...... gonna see about that first thing fri am.........
any body got any suggestions?
Old Nov 22, 2007 | 12:25 PM
qzilla's Avatar
The trans temp is 300 degrees because of 1 or 2 things.
1.) Either what you are screwing the probe into is not grounded (ie hotline)
2.) You did not use the fiber washer and the signal wire is getting grounded out.
Old Nov 22, 2007 | 12:45 PM
CamperAndy's Avatar
Why do you think the Commander should be able to control the Edge Juice??
06CTDforAU
37
Jul 28, 2007 07:21 PM
rjm022
Mar 28, 2007 06:29 AM
JThiessen
14
Feb 5, 2007 10:36 PM
stock03
Nov 9, 2006 11:27 PM
JThiessen
Oct 3, 2006 10:30 AM
